What Is The Proper Pre-charge PSI For Thermal Expansion Tanks? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 05:01 PM   #1
Question
What is the proper pre-charge PSI for thermal expansion tanks?
OK, OK. I have read SO MANY conflicting ideas on what the "pre-charge" or air pressure should be set for a thermal expansion tank. Why are there so many different opinions on this - isn't there some standard for this, uggg!!
1) WATTS says to set the thermal expansion tank to the same PSI as your "static" or "base" water pressure (i.e. same as pressure reducing value or PRV).
2) Water heater company (Rheem) suggest 10-15 PSI ABOVE the static or base water pressure.
3) I have read from others that say your bladder can get stuck if pressurized to high, so they suggest 2/3 or even 1/3 PSI of the static or base water heater.
Plumber installed thermal Expansion tank without adjusting pre-charge
byoder is offline   Reply With Quote
Old 02-02-2011, 05:30 PM   #2
Water Treatment
Rewards Points: 902
Not sure if I can give the right answer, only what mine is charged to..
14psi
I run a single loop system, so I do not know that should be different if there are more than one loop on your system.
Where you taking an old one off and putting a new one in?
Some times a plumber will write on the tank some information, when installed and the pressure are some of the things that some will do, I know that mine did.
That information saved my butt when my system went down at -20 in December.. I was able to get things bad up and running again for now and will finish when spring or summer get here.
Akpsdvan is offline   Reply With Quote
Old 02-02-2011, 07:19 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 902
If you go to this link, you'll find a short video for adjusting a Watts tank http://www.watts.com/mediaCenter/
Old 02-02-2011, 07:32 PM   #4
Picky Plumber
14psi
I believe that you are referring to your boiler and the OP is referring to his potable water system. I always say, when in doubt, do as the manufacturer recommends. I've always set them to the same pressure as the system it serves. If the PRV is set @ 60 psi, then the tank is set @ 60 psi. Make sure you add the air before you install it.
__________________________________________________ _________
If you can't do it the RIGHT way, call me!
Plumber26 is offline   Reply With Quote
Tags
Charge line from car to trailer Scardey eCat Electrical 7 10-24-2010 10:38 PM
Expansion Tanks Questions wannabuild Plumbing 3 02-01-2007 02:14 PM
