What Possible Problems With Unpermitted Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2014, 04:41 PM   #1
Rewards Points: 682
What possible problems with unpermitted water heater?
We are looking at a house where the water heater has been moved outside. While this is generally a good thing, the install has no permits. What possible problems can exist with an installation like that with no permits?
darsunt is offline   Reply With Quote
Old 02-27-2014, 05:55 PM   #2
Civil Engineer
Rewards Points: 4,860
The fact that it lacks a permit tells you nothing. What is important is whether it was correctly installed, and meets code. This can be verified by hiring a plumber to inspect the installation.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
oh'mike (02-27-2014)
Old 02-27-2014, 06:38 PM   #3
Rewards Points: 2,040
Outside by outside do we mean it gets rained on? Or do we mean outside into a garage?
Old 02-27-2014, 07:56 PM   #4
Rewards Points: 682
It is installed in a roofed shed outside the house. May have a plumber look at it.
I would think it easy to keep an outside water heater in code. Exhaust venting, its outside already. Earthquake straps. Base of heater a certain distance above the ground.
Old 02-27-2014, 08:05 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Your in my neck of the woods....
As long as it has straps....PRV is vented outside the shed....proper vent pipe used (no flex pipe). Shut off valve at the WH...with proper dirt trap.
I believe that you now have to have it wrapped in insulation...which is a good thing.
If you want...post pics....it will make it easier to tell you if anything.
You can call the building and safety office to see what permits have been pulled on the house. If a lot of stuff was done without a permit...then you can either walk away and get your deposit back or use it as a bargaining tool to get the price down.
If you do buy the house....they will come out and inspect it...there might be a slight extra fee...but better safe than sorry.
If they did a remodel of something without a permit...and your thinking of changing it...then pull permits as if you were going to do it....then have them inspect it at the normal steps. If you are redoing something, they are not going to care about previous work...just the new stuff.
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
