Old 05-14-2008, 09:04 AM   #1
What to plug sink, toilet lines with, No Shut off valve for house?
I want to turn the water off to the house but there is no water valve for the house. There is one at the street and I turn it off when I need to turn the water off. However, I still need my spigot to have water so I can clean etc, but I need to remove the toilet, sink and faucet etc. and none of them have shut offs on them. (house is older)
I am going to redo all of the plumbing but for now I want to still have water but be able to remove the toilet, sink etc. How can I plug or cap each inlet line so I can turn the water on and remove these pieces. Thanks.
twilightcall is offline   Reply With Quote
Old 05-14-2008, 09:25 AM   #2
Moderator
Termite's Avatar
You'll have to shut the water off at least for a while.
The answer to your question depends on what type of plumbing system your house has. Copper pipe? Galvanized?
Either way, you can get caps to go on the ends. If it is copper, you'll have to cut the pipe at each fixture and solder a pipe cap on the cut end. If you don't know how to do this let us know and we can explain. It is fairly easy if you're handy, but it is best to see it demonstrated.
If your pipes are threaded galvanized pipe, you'll have to find a place to unthread two fittings to expose a male end that you can screw a cap onto. You'll need two pipe wrenches, appropriate galvanized caps, and teflon tape.
Old 05-14-2008, 09:50 AM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What thekctermite said - For me, I would not cap the ends but instead cap the supplies with an appropriate shut-off valve if possible. This isn't always possible in a remodel because the valves can get in the way of things like drywall.
Brik is offline   Reply With Quote
Old 05-14-2008, 10:07 AM   #4
Thanks guys. It is galvenized plumbing. I am switching to pex. Any info would be appreciated.
Old 05-14-2008, 03:02 PM   #5
The first thing I'd do is shut off the water at the street, and install a shut-off valve after the meter in my house. At least around me it's illegal to touch anything on the city-side of the meter, so it would be best to put a valve in for future work.
NateHanson is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
