What Is This Pipe And Why Is Water Always Coming From It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2009, 09:17 PM   #16
Rewards Points: 1,494
I wanted to say plug it up so you don't waste metered water.
The pitfall I saw was if you have a backflow preventer on the feed from the water main and no expansion tank for your water heater. This combination could lead to unusual pressure buildup in your system where a pressure relief valve would be needed.
Does twisting the plastic dial stop the trickle? If so adjust the dial to just at the point where the trickle stops.
Old 04-02-2009, 11:18 PM   #17
Is it possible that someone else said "I wonder what this is" and turned the knob?
hayewe farm is offline   Reply With Quote
Old 04-03-2009, 10:22 AM   #18
HVAC / Plumbing
On the ones I've seen like that . It's not actually a knob that you can adjust.. It's more like a cap.. The relief in the valve is per set at the factory... Might be worth a shot to try.. I don't think I would force it to turn with water turned on incase it were to snap off
kenmac is offline   Reply With Quote
Old 04-03-2009, 10:50 AM   #19
joed's Avatar
Rewards Points: 12,388
Are you sure it's a pressure relief valve? It could be an auto trap primer. Everytime water is used it trickles water to keep the trap filled. Prehaps that sink wasn't used very often at one time and the trap was drying up.
Tags
basement , plubming , running water
