What Pipe To Use - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2010, 05:28 PM   #1
Newly Retired
tuchodi's Avatar
What Pipe to Use
I am going to replace all the hot and cold water lines in my house which is 30 years old. It has copper now so what should I use to replace it with. Should I stay with Copper or use Pex. What size would you recommend 1/2" or 3/4" or a combination of both.
tuchodi is offline   Reply With Quote
Old 05-12-2010, 06:19 PM   #2
why are you replacing 30 yr old copper? pex is obviosly the cheapest way to go but if the house is not too big with alot of piping coppers the better choice in my opinion
just a guy is offline   Reply With Quote
Old 05-12-2010, 07:36 PM   #3
the Musigician
DangerMouse's Avatar
combination.
DM
Old 05-12-2010, 08:12 PM   #4
Newly Retired
tuchodi's Avatar
I am on a well and the water is very hard. I just bought the house about 8 months ago and the water softener has not worked for some time. There is no large amount of iron mostly calcium and there is a large build up of deposit in the lines. I have had to do some repairs already. I am installing a new softener so build up should be not a problem. I know Pex is cheaper but if copper is better thats what I may go with.
combination.
When you say combination what do you mean? What part Copper and what part Pex?
Old 05-12-2010, 09:06 PM   #5
the Musigician
1/2" & 3/4"
3/4" main, 1/2" off to sinks, etc.
DM
Old 05-12-2010, 09:34 PM   #6
Newly Retired
tuchodi's Avatar
Originally Posted by DangerMouse View Post
1/2" & 3/4"
DM
Yes I was going to do that but are you also suggesting a combination of Pex and Copper and if so where would you use each product?
Old 05-12-2010, 09:45 PM   #7
GC/Master Plumber/Mech
Rewards Points: 560
If you are not having any pressure issues like pressure drops when toilet is flushed then when you replace a 1/2 copper use 1/2 pex, 3/4 copper use 3/4 pex
If you have pressure issues then you may want to resize you home
Also if you have hard water try and use as little fittings as you can. The brass fittings can corrode.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
