What Is This Pipe - Can I Cut It Off? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2009, 06:41 PM   #1
Rewards Points: 1,016
What is this pipe - can I cut it off?
Hoping someone can help me by identifying what this pipe is (circled in each picture)?
Its PVC and makes a 90 degree turn and goes up the wall to where I have not looked. It is as it was when the old bathroom vanity was removed. I ask because I would like to cut if off flush with the wall would save cutting on the back of the new vanity.
Thanks!
Vince
What is this pipe - can I cut it off?-what-pipe-2.jpg   What is this pipe - can I cut it off?-what-pipe-1.jpg
Old 06-18-2009, 08:25 PM   #2
31b
sparky
could be a sewer vent pipe
31b is offline   Reply With Quote
Old 06-18-2009, 08:43 PM   #3
master plumber
cincy plumber's Avatar
Looks like 1"sch 40.should have capped it off be fore you closed it up.
cincy plumber is offline   Reply With Quote
Old 06-18-2009, 09:04 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
though either of the top posts might be correct, I think I would explore as to why it is there in the first place before I did anything. It must have been there for a reason at one time. Maybe a water supply to a fridge, who knows, but at least find out where it is going.
Man of many hats
wrangler is offline   Reply With Quote
Old 06-18-2009, 09:26 PM   #5
master plumber
Should have been explored before the wall was closed up.
Might be a condisate line for for an RTU/AC?
Old 06-18-2009, 10:57 PM   #6
It's a one owner home, so we know 25 year history of the house. Not a refrigerator or for AC condensation. Some kind of a vent maybe - but what would just vent into the room.
There is no odor, water drip, or appearance of past water on the pipe.
Guess I need to go for a crawl through the attic. Or just cut a hole in the vanity and live with the mystery.
Old 06-18-2009, 11:07 PM   #7
master plumber
Yep that might be good idea,in any case it should be capped off.
Old 06-19-2009, 03:26 PM   #8
Rewards Points: 252
crazy idea but could it just be a chase for running future wires or something??? Not too much use for 1" PVC. Condensate line was my first guess but it goes up to the attic, so that rules out anything draining from the bathroom...anything in the attic that would require a drain? If so, I would imagine that after 25 years you would have noticed some water =). Nothing else to do but crawl around the attic and find where the mystery pipe goes..
good luck!
mazzonetv is offline   Reply With Quote
Old 06-21-2009, 12:52 AM   #9
Today I investigated the attic. Contray to what I thought, it does not extend up through the top plate into the attic. I had removed only the bottom 4 feet of drywall and made the assumption it continued to the attic.
So the mystery remains...
Whatever it's purpose, is does not seem to have done anything overt during the past 25 years. I made the command decision to cut the pipe flush to the wall.
Thanks everyone for the help!
Old 06-21-2009, 05:45 AM   #10
2 fingered typer
woodnthings's Avatar
ONe last question?
What's on the wall behind this wall? Is there another room or is it an outside wall? This may provide your answer. bill
woodnthings is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
