I need to add on to the existing rain drain system on my house for 3 new downspouts.
The pipe I need to connect to is white and 3 1/2" OD.
Is this schedule 80 PVC?
The places I have looked do not have these fittings or the pipe.
Can I connect ABS to the PVC with all purpose cement?
I tried a piece of my pipe in the ABS fittings and it is kinda tight, is this ok? It seems to be very close to the same diameter as 3" pvc when I measure it.
One more question --- I have a section I need to connect to that the pipe is in concrete on either side so no way to move the pipe to install fitting, can I cut the pipe just big enough to slide the tee in and then slide it only halfway in on either side? or what is the correct procedure?
Thanks, for any help
