-   -   What pipe is this? can I connect abs to it? (http://www.diychatroom.com/f7/what-pipe-can-i-connect-abs-100414/)
oregondiy 04-03-2011 04:49 PM
I need to add on to the existing rain drain system on my house for 3 new downspouts.
The pipe I need to connect to is white and 3 1/2" OD.
Is this schedule 80 PVC?
The places I have looked do not have these fittings or the pipe.
Can I connect ABS to the PVC with all purpose cement?
I tried a piece of my pipe in the ABS fittings and it is kinda tight, is this ok? It seems to be very close to the same diameter as 3" pvc when I measure it.
One more question --- I have a section I need to connect to that the pipe is in concrete on either side so no way to move the pipe to install fitting, can I cut the pipe just big enough to slide the tee in and then slide it only halfway in on either side? or what is the correct procedure?
Thanks, for any help
MarkusAIC 04-03-2011 10:33 PM
White PVC is typically schedule 40
ABS and PVC are not generally meant to be mixed. I have heard that there are adapters between the two. Since ABS isn't allowed here I don't know for sure.
NO, you can't use all purpose cement. Buy a can of PVC cement so that you can ensure a sound joint.
plumber666 04-04-2011 08:18 AM
Yes you can join them. Buy a product called transition glue to connect the different pipes. Use primer on the pvc side, but not the abs side.
DangerMouse 04-04-2011 08:33 AM
This is also true for me in my area, so be sure to check first before you do all that work only to have to remove it and do it all again.....
DM
