What Is This Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By Yodaman
Old 01-04-2017, 07:21 PM   #1
Rewards Points: 6
What is this pipe?
So I went to check on my electric water heater in the basement ,when a drop of water hit me on the head. I looked up and this pipe coming from the ceiling
Now, it's not attached to anything(@least from down here). I live in western MA in a Dutch colonial built in 1991.
I've never seen this leak before! Any ideas?
Askin is offline   Reply With Quote
Old 01-04-2017, 07:53 PM   #2
Gymschu's Avatar
Rewards Points: 1,034
Re: What is this pipe?
Just a guess, but maybe a metal vent pipe for your water heater that has been abandoned due to the newer codes set forth that require horizontal venting. When it gets cold, perhaps there is some condensation going on which would explain the water dripping.........
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
Old 01-04-2017, 08:03 PM   #3
joed's Avatar
Rewards Points: 13,746
Looks like drain pipe size. What is above it? Is there an attic? Can you get up there and see if it goes up through the roof?
Old 01-05-2017, 01:04 AM   #4
Rewards Points: 46
I agree, and it's going through combustibles, so not exhaust.
Cheers!
supers05 is offline   Reply With Quote
Old 01-05-2017, 07:05 AM   #5
Property Mgt/Maint
Rewards Points: 1,676
If that is a open chase from basement to attic it should be sealed at both ends to prevent moist air from the basement migrating up into the attic.
Tom738 and supers05 like this.
Yodaman is offline   Reply With Quote
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
