Old 01-09-2013, 11:05 AM   #31
JOATMON
ddawg16's Avatar
What is this pipe?
Originally Posted by BabsHoney View Post
Ooh!
I forgot their used to be a gas heater underneath this particular floor.
The thermostat is still in the wall but the heater is gone (???)
It's not a gas pipe....it's not a heater flue.....I'm assuming that the end of the roof is open...so it has to be a vent.
If it was me, I would be grabbing a small shovel and diging down around the pipe.....find out what it threads into. Assuming you can get to the threads....I would just unscrew each section...and when you get to the below ground point....just screw a plug into that part.....call it done.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
BabsHoney (01-09-2013)
Old 01-09-2013, 11:55 AM   #32
Gymschu's Avatar
What is this pipe?
Those old vent pipes are a joy to remove......NOT. It looks to be galvanized and will be plenty heavy.......cutting it without the proper tools is a treat also. I cut my old stack with a hacksaw blade and my sawzall. Took some time and I had to be careful to secure the pipe somehow because it was so heavy. Replaced with PVC and have had no problems.
Old 01-09-2013, 01:17 PM   #33
Newbie Bill
What is this pipe?
I love mysteries.
Keep us updated.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-10-2013, 02:50 PM   #34
BabsHoney's Avatar
What is this pipe?
Well, we finally have a chance today to get in this room and work.
We cut out a space in the floor planks and took some pics.
The third picture is another pipe under the floor that had already been cut off.
Now we're arguing about what to do next. Leave it or cut it. The plumber said cut it but he hasn't seen it in person, only pictures.
What is this pipe?-image-1282492832.jpg   What is this pipe?-image-501897852.jpg   What is this pipe?-image-2790790634.jpg
BabsHoney is offline   Reply With Quote
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 03:46 PM
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 9 08-21-2011 03:17 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
