What Is This Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2013, 11:46 AM   #1
BabsHoney's Avatar
Rewards Points: 150
What is this pipe?
Second question for the day! Yay! :-/
Anyway, we have this pipe... in our bedroom...
In the pictures on the opposite of the wall is our shower, but this pipe doesn't line up with any of that plumbing. To the left is the kitchen sink but all of the plumbing is under the sink, none of it is in the wall.
This pipe makes it's 90 degree turn high enough from the floor that it stuck out above the floor that was here before. I would like to see if there is a way to fix this problem. We're going to put down a new wood floor and I really don't want a pipe sticking up through it!
So, advice? Opinions? Laughter?
Oh yeah, it's hard to tell in the photo, but yes, there is aluminum foil bunched up and "wrapped" around this joint.
And... we're pretty sure this used to be an exterior wall if that means anything.
BabsHoney is offline   Reply With Quote
Old 01-04-2013, 11:54 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Question for you- do you have a basement? It looks like a vent from a fixture below and it was offset around the foundation or a beam
Old 01-04-2013, 11:54 AM   #3
Rewards Points: 13,300
Are those two pipes connected?
The one running straight up could be a vent line, should be running all the way up through the roof.
Any of those old steel drain and or supplys need to be removed and replaced with PVC for the drains and copper, CPVC or Pex for the supplys.
Steel will fail everytime at some point.
Drains for the sinks need to be run into the walls not just a hole in the floor to make it legal.
Old 01-04-2013, 11:59 AM   #4
BabsHoney's Avatar
Rewards Points: 150
We have a dirt crawlspace. This pipe comes ups from the crawl space and then appears to go straight up and out through the roof.
The kitchen and bath plumbing will all be redone, but I wasn't expecting to deal with plumbing in the bedroom.
Man... I'm gonna have to go in the crawlspace. Blech.
Old 01-04-2013, 01:10 PM   #5
Roofmaster
Rewards Points: 2,172
If it goes through the roof it is a plumbing vent. How about some more info?
Type House, Year Built, etc etc.
If you are re-plumbing your home you should be able to re do the vents and get rid of that pipe altogether.
Dirt Crawl Space??? Re-Plumb could be tough.
Old 01-04-2013, 01:13 PM   #6
BabsHoney's Avatar
Rewards Points: 150
Hrm... type of house?
Poor man's shack that has been piece-mealed together.
At least one part of it was built in 1937.
It's only 743 square feet.
Old 01-04-2013, 01:21 PM   #7
BabsHoney's Avatar
Rewards Points: 150
Well I called the plumber my family uses.
(I really don't want to go in the crawl space.)
He said it may be for gas??
Anyway, I sent him pictures of it but he can't come look till next Friday.
Old 01-04-2013, 01:23 PM   #8
Plumber
Rewards Points: 452
It's not gas.
Pretty sure it vents a nearby fixture(toilet) or maybe even an abandoned fixture
The Following User Says Thank You to TheEplumber For This Useful Post:
BabsHoney (01-04-2013)
Old 01-04-2013, 01:28 PM   #9
BabsHoney's Avatar
Rewards Points: 150
I didn't think it was anything gas related, but I also wasn't doing an awesome job describing it. Hence the pictures.
Old 01-04-2013, 01:32 PM   #10
If you need to move it, move it over to the wall in the left. It's just a vent. I'm guessing you had a cabinet there or something before. It's common to run it like that if there is a beam or something you cant go through. move it over if possible and connect it back with the plumbing that goes through the roof or go straight up where you move it to.Hope that helps
fasteddie3 is offline   Reply With Quote
The Following User Says Thank You to fasteddie3 For This Useful Post:
Old 01-04-2013, 01:34 PM   #11
If it runs up and out the roof it's a vent.
No way it's for gas.
Depending on how old this house is, some really old houses had no need for vents because there was no plumbing.
Once inside plumbing came into play no one want to bust out the walls to run the vents the right wal so that did the next best thing.
Some were even run outside of the house. I love it when I see the lines ending right under a soffit vent or a window.
Old 01-04-2013, 01:37 PM   #12
BabsHoney's Avatar
Rewards Points: 150
From what we can tell the house wasn't built with any indoor plumbing.
I'm feeling optimistic about being able to move it though, thanks so much everybody!
And as soon as I know more I'll update.
Old 01-04-2013, 08:04 PM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If it isn't serving any purpose there's a chance to eliminate it and a roof penetration, which of course means getting a roofer to come patch over the hole.
Your plumber will guide you well.
Journeyman Plumber
Old 01-04-2013, 08:09 PM   #14
BabsHoney's Avatar
Rewards Points: 150
The roof is getting redone this spring as well
Old 01-04-2013, 08:17 PM   #15
cdaniels's Avatar
plumbing vent would be my guess
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 03:46 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
