What Parts Do I Need To Connect My Sink To The Drain Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 01:52 PM   #1
Rewards Points: 184
What parts do I need to connect my sink to the drain pipe?
I removed my garbage disposal and mounting assembly, now what do I need to connect my sink to the drain pipe? Right now there is just a big hole in the sink, with not catch basket or anything.
It is better to replace a broken garbage disposal, or remove it and put in just piping.
abefroman is offline   Reply With Quote
Old 06-16-2010, 04:46 PM   #2
DIY staff
Rewards Points: 7,174
You need--Strainer basket---tailpiece washer(usually comes with basket)--tailpiece--P-trap--and plumbers putty.
That's a start--1 1/2 inch is the size--PVC --cuts easily with a hack saw or any other fine toothed saw.
I use my Japaneses pull saw--or a Sawsall with a hacksaw blade.
Take a picture of the piping--bring it to the store with you as a reminder.--Mike--
Old 06-17-2010, 02:27 PM   #3
Owner
LateralConcepts's Avatar
That's definitely a start. Also depends on whether it's a single or dual basin sink you'll most likely need a center, or end outlet continuous waste. depending on your sink configuration and location of the drain in the wall. May also need a new trap adapter.
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
oh'mike (06-17-2010)
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
How to fix bathroom sink drain pipe ? cprao Plumbing 9 02-27-2010 08:15 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
