-   -   What parts do I need to connect my sink to the drain pipe? (http://www.diychatroom.com/f7/what-parts-do-i-need-connect-my-sink-drain-pipe-73884/)
abefroman 06-16-2010 02:52 PM
I removed my garbage disposal and mounting assembly, now what do I need to connect my sink to the drain pipe? Right now there is just a big hole in the sink, with not catch basket or anything.
It is better to replace a broken garbage disposal, or remove it and put in just piping.
oh'mike 06-16-2010 05:46 PM
You need--Strainer basket---tailpiece washer(usually comes with basket)--tailpiece--P-trap--and plumbers putty.
That's a start--1 1/2 inch is the size--PVC --cuts easily with a hack saw or any other fine toothed saw.
I use my Japaneses pull saw--or a Sawsall with a hacksaw blade.
Take a picture of the piping--bring it to the store with you as a reminder.--Mike--
LateralConcepts 06-17-2010 03:27 PM
That's definitely a start. Also depends on whether it's a single or dual basin sink you'll most likely need a center, or end outlet continuous waste. depending on your sink configuration and location of the drain in the wall. May also need a new trap adapter.
