What Are The Odds Of This Leaking. - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2008, 10:43 AM   #1
Rewards Points: 154
What are the odds of this leaking.
I was working under the house last week and accidently dropped some equipment on this 1/2 copper water pipe. Should I put this on the top of my "to do" list? Can I just leave it?
What are the odds of this leaking.-img_3942.jpg   What are the odds of this leaking.-img_3943.jpg   What are the odds of this leaking.-img_3946.jpg
ovahimba is offline   Reply With Quote
Old 12-05-2008, 11:01 AM   #2
Registered User
Termite's Avatar
Copper is pretty malleable, so I wouldn't panic. However, there's a good chance that it damaged it enough that it could force a leak at the crimped point. I'd suggest replacing it in the near future just to be safe.
Old 12-05-2008, 12:52 PM   #3
I would not bury it in a wall, but it should not be an immediate problem. One thing you do not want to do is try to straighten it out. This would probably cause it to crack and start leaking.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-05-2008, 01:42 PM   #4
RippySkippy's Avatar
Replace it...it's the right thing to do...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 12-05-2008, 07:25 PM   #5
Rewards Points: 2,906
I'd agree with The KCTermite and Majakdragon on this one.
Copper is one of the most formable metals, which makes it ideal for drawing into wire and making into pipes. You can also bend copper piping with an electrician's conduit bending tool.
In my view, if it's not leaking now, it can last forever like that.
The quick bending of the pipe wouldn't have put any cracks in it. That's explained on this web page:
http://www.launc.tased.edu.au/online...e/BondTyp4.htm
You don't want to bend that pipe back to straighten it because it's been "work hardened" at that bend. If you try to straighten it out by bending it back, the work harded area will be stronger than the rest of the pipe, and it will bend backward in a different spot.
Ideally, it would be best to have a straight pipe. But if that bent pipe isn't leaking now, and no one messes with it, it won't leak in future either.
Nestor_Kelebay is offline   Reply With Quote
Old 12-06-2008, 09:20 AM   #6
Rewards Points: 154
Thanks for the feedback everyone. I suspected it would never leak but just so I'll never have to think about it again, I'll probably spice in some new pipe.
Old 12-06-2008, 09:31 AM   #7
the Musigician
DangerMouse's Avatar
i gotta go with rippyskippy on this one, it's easily accessable right now and involves a coupler and a 5 minute fix. i'd repair it.
sure, it MAY never leak, but if it's fixed, YOU know it's safe.
DM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
leaking pipes tina cosio Plumbing 2 10-26-2007 09:39 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
