What A Mess.. Kitchen Plumbing Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2013, 01:05 PM   #1
What a mess.. Kitchen plumbing help
I am doing a minor renovation around the house, the countertops are being refinished and I will install new sinks and faucets in the baths and kitchen.
Looking at the kitchen plumbing, it is kind of a mess. (picture at the bottom) The person that installed it /rigged it up used 2 p traps into a wye.
I want to plumb it using only one p trap, but I don't know what to do about the wye connection. It is glued in, right at the base of the wall - so I don't know if I would be able to cut it out to replace it with a single pipe.
Will it work if I simply plug the unused inlet? What would you all recommend?
Thanks!
molecularman is offline   Reply With Quote
Old 05-25-2013, 02:24 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
I would verify that the wye is glued close to the tee first. If not, cut it off next to the hub and glue on a coupling and build out from there.
If you can't do that then it's OK to cap one side of the wye- but cap it with a female adapter and plug.
Also, plan carefully which one to cap- I'd think about using the branch side for an end outlet waste assembly- but you can make that call...
Old 05-25-2013, 09:18 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,186
Some local codes require 2 traps for a 2 bowl kitchen sink.
Coastal South Carolina
Old 05-25-2013, 09:42 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
True, but that doesn't apply here and our kitchen sinks work just fine.
That said : If you're not looking at codes, i'd leave the wye there just in case someone was ever to look at it and want it put back with separate traps.
Journeyman Plumber
Old 05-25-2013, 10:35 PM   #5
Lord of Slums
Rewards Points: 1,974
What is wrong here? I know the height is wrong, at least for the water lines. Why is this an improper way to have the sink drain correctly?
mj12 is offline   Reply With Quote
Old 05-25-2013, 11:51 PM   #6
Plumber
Rewards Points: 556
Nothing really- some areas use 2 traps, others don't
Old 05-26-2013, 10:33 AM   #7
Doing it myself
Alan's Avatar
Technically 2 traps on a single trap arm is a UPC violation, but it would probably work just fine.
Journeyman Plumber
Old 05-26-2013, 10:49 AM   #8
Thanks for all the feedback.
I had no idea that two p traps can be considered proper. The sink works fine as it is, so I might just end up leaving - but replacing the metal pipes as some are corroding.
I just figured plumbing it with 1 p trap would clean it up and give a little more storage space underneath the sink.
Kitchen sink replacement - plumbing questionable.... batistuta Plumbing 27 04-07-2012 12:04 PM
Kitchen plumbing set-up. Is this ok? oba97 Plumbing 8 01-28-2012 01:47 PM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
DIY Kitchen Island Plumbing question bayin Plumbing 6 03-27-2011 09:55 AM
moving the kitchen - connecting plumbing timbo59 Kitchen & Bath Remodeling 0 05-03-2010 10:39 AM
