Old 04-19-2010, 02:44 PM   #1
what kinda wrench would help?
hello, i'm trying to get this (pictured below) elbow piece off, because it leaks somewhere b/w it and the straight pipe it connects. but, as you can hopefully see here, there's a stud preventing my pipe wrench access to the elbow. so, i have no idea how to get it off w/o removing part of my stud. just wondering if it is possible to do w/o doing that?
thanks everyone
plumbtastic is offline   Reply With Quote
Old 04-19-2010, 03:22 PM   #2
the Musigician
DangerMouse's Avatar
HI and welcome.
I that a coupler above the threaded piece? That may be the answer.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-19-2010, 03:31 PM   #3
i'm not sure what's what to be honest. do these pics help more?
Old 04-19-2010, 03:38 PM   #4
the Musigician
Is that the tub spout in the last pic? Remove that first.
Then the elbow should remove easier, IF that's where it's leaking, but I suspect not.
(My buddy here says just grab your sawzall... LOL)
DM
Old 04-19-2010, 03:52 PM   #5
that last pic is the tub spout. and that's where the elbow leads to. if i am able to twist it out, I'd still be stuck w/ the same problem of not having access to the elbow on the back, wouldn't i?
here's another pic showing where we think the leak is originating:
Old 04-19-2010, 04:04 PM   #6
the Musigician
I don't see any signs of water damage there, are you sure it wasn't the straight piece the spout attaches to? Did it leak under the spout?
Remove and inspect that first.
DM
Old 04-19-2010, 04:25 PM   #7
you probably cant see any signs because i've let it dry out and not get too far along.
when I have the tub spout hooked up and running normally, it drips a steady leak right at the bottom of the elbow. it'd either coming from the straight tub spout piece, or the connection b/w it and the elbow, or maybe at the elbow and the 'coupler' above the elbow.
i just need to get the elbow off there, to have a look and maybe just replace all 3 fittings, i think.
Old 04-19-2010, 04:40 PM   #8
the Musigician
Well, regardless of whether or not that is where the leak is, there is no way the elbow will rotate with that piece on it, it MUST be removed first.
(be careful around that tile) Then a pipe wrench should turn the elbow and/or threaded nipple piece off. Are you sure that's a support stud?
It looks like a 4x4!
DM
Old 04-19-2010, 06:17 PM   #9
It was a dark and stormy
Yoyizit's Avatar
Any objections to cutting it off? With a 1/16" thk abrasive disk in an arbor in an elec. drill?
Old 04-19-2010, 10:43 PM   #10
I would remove the stud
plumberinlaw is offline   Reply With Quote
Old 04-20-2010, 05:25 AM   #11
cut 90 off with sawzall, and putt back with copper male adapter and 90
just a guy is offline   Reply With Quote
Old 04-20-2010, 10:43 AM   #12
im liking the option to chop it off and not have to rebuild my stud...
Yoyizit, what kinda tool or bit is that? can you provide a link or something where i could see it please?
Old 04-20-2010, 11:09 AM   #13
Remove the nipple on the inside of shower/tub with a pipe wrench or chain wrench being careful of the tile. Then remove the two unions on the backside of wall on either side of that stud. With unions removed move the el to the right for enough room to turn it cc to remove. May need two chain wrenches, one to hold the nipple between the el and the body and one to turn the el. Just a suggestion.
P.S. To protect the tile place a piece of cardboard or luan with hole to fit over the nipple/spout against the tile.
P.S.S. If you have a pipe for the shower supply running up the wall, may have to unscrew it in order to get the movement of the manifold you need as you may have to move it up then over a little ikn order to get the el far enough away from the stud to turn it.
Good luck.
Old 04-20-2010, 11:20 AM   #14
With luck, you may be able to pull the el toward you when everything is taken apart to get beeter working leverage for removal of the el.
Old 04-21-2010, 09:09 AM   #15
Yoyizit's Avatar
http://i287.photobucket.com/albums/l...tting_disc.jpg
The Following User Says Thank You to Yoyizit For This Useful Post:
plumbtastic (05-02-2010)
Help with Impact and Ratchet Air Wrench Comparison, Confusing Specs don’t match caliskier Tools 5 03-15-2009 11:33 PM
what wrench for a radiator fitting drewhart HVAC 9 01-07-2009 05:04 PM
spud wrench problem drewhart HVAC 3 01-06-2009 09:41 PM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-25-2008 12:47 AM
Makita Impact Driver vs Wrench HELP! the496rocket Tools 8 02-14-2006 08:41 PM
