What Kind Of Wye Do I Need? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2011, 04:32 PM   #1
what kind of wye do I need?
I'm moving a toilet, which means I have to tie into the main sewer line.
Also, I've never done this before.. I'm not a plumber, so please be kind
I dug down to the sewer line closest to where the toilet will be installed and found this:
To the right heads out to the street and the sewer. To the left is the rest of my bathroom and the end of my house.
The plasic pipe is the shower & sink drain for the bathroom. The toilet is currently a few feet to the right, but in order to move it would require me cutting supports to have it drain to its current location.... which I'd rather avoid doing if possible.
Anyways, What kind of wye would I need to basically replace that fork that's currently there. I'd leave the 2" drain, if possible.
Thanks for your help.
Please let me know if you need more information
graysqwrl is offline   Reply With Quote
Old 06-21-2011, 05:08 PM   #2
I was thinking it might be best if I used a 4" tee leading into a 4" 45 degree elbow and couple that to the end of the pipe before the cast iron wye where the 2" is. That would put me slightly to the left from where I want to be, but I'm sure I can work that out.
Does that sound like the best solution?
Old 06-21-2011, 06:29 PM   #3
Rewards Points: 41
i'm not an expert, but
It appears to me that the flow in your picture is from right to left.
You may want to double-check so that a real expert can help you better.
Sorry I don't have an answer to your question.
Tom
tom31415926 is offline   Reply With Quote
Old 06-21-2011, 06:40 PM   #4
Nope... I'm quite sure it's from left to right.
It looks like the 2" was installed backwards. Someone recommended I cut on the other side of the 2" wye and replace the whole run... which I might do.
Old 06-21-2011, 07:40 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 564
Flow direction of that wye is right to left. Is that building drain a 3 or 4" pipe? 3" is minimum for a toilet.
I'd cut down stream of that wye, attach to the pipe with the new fittings and route it to your new toilet. Tie in the existing 2" where possible.
Old 06-21-2011, 11:17 PM   #6
I stand corrected...
I dug out quite a bit more and got out the level. Sure enough it runs right to left.
It's kind of odd because neighbors have told me that the sewer is out in the street (which would be to the right). To the left runs to the rear of my property. Oh well... you live, you learn (I only bought the property last year)
The building drain is 4"
I suspect I need a 4" x 4" x 4" sanitary wye & street 1/8th bend or sanitary combo to create the vertical stack for the toilet, then I need a 4 x 4 x 3 sanitary tee to be placed vertically where the 3" runs to the toilet?
is that correct?
Thank you for your help.
Old 06-22-2011, 04:23 PM   #7
a sketch of what you are intending to do in relation to what you have would be helpfull
just a guy is offline   Reply With Quote
Painting Baseboards(does it matter what kind?) SabineTLK Interior Decorating 12 02-06-2011 07:34 AM
Looking for a kind of pest killer spray userid Pest Control 1 05-04-2010 07:06 AM
what kind of pipe to use clasact Plumbing 24 10-05-2008 12:48 PM
What kind of breaker TaazKareem Electrical 22 09-26-2008 10:03 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
