Old 07-01-2012, 12:51 AM   #1
What kind of Water Softener do I have and how does it work?
We moved into a house a few years ago and a Water Softener was already installed and working. I can hear recharging every few nights at 2:00AM.
It appears that the unit is working as I have to add 3-bags of 40-lbs salt every 7-10 days. I do not know how to adjust the unit for the proper amount of water hardness and salt settings, etc.
This unit is approximately 9-years old and I have only seen the following marking on the water tank. See attached picture.
Any input is appreciated.
charliebeagle is offline   Reply With Quote
Old 07-01-2012, 10:01 AM   #2
You have a Fleck 5600 control head.
You can download literature here:
http://www.pentairwatertreatment.com/en-us/Products/ResidentialControlValves/Fleck+5600.htm
You will need to know the amount of resin and that can be determined by the size of the resin tank.
There should be a label on the resin tank giving the diameter and height but if not you will need to measure.
A 9X48 resin tank holds 1 cubic foot of resin
10 x 44 is 1.25 ft2
10 X 54 tank is 1.5 ft2
12 x 48 is 2 ft2.
8 x 44 is .75 ft2
Each cubic foot is a nominal 32,000 grains capacity.
Bob999 is offline   Reply With Quote
Old 07-01-2012, 10:38 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Can you please resize your picture. It is way too large, and is blowing out the margins.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-02-2012, 10:40 AM   #4
You use three bags of salt a week?? That seems like way too much. I have very hard water, and my softener barely uses one bag a month.
