What Kind Of Valve Is This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2011, 08:57 AM   #1
What kind of valve is this?
I have two sinks and they are starting to get old and may need to be replaced. I am not a plummer and I don't know what kind of valve I currently have.
Can someone please help me out and tell me what kind of valve these are:
First Sink:
Second Sink:
Thank you.
mwong is offline   Reply With Quote
Old 12-05-2011, 09:26 AM   #2
DIY staff
Rewards Points: 7,174
That's a ball valve with a drain cock---usually used for outside hose bibs---That one appears to be installed backwards--the drain cock is on the pressure side--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
mwong (12-05-2011), rossfingal (12-05-2011)
Old 12-05-2011, 09:30 AM   #3
Is it a sweat or threaded ball valve? I can't tell because of the mineral deposit build up but I would think that this is a sweat ball valve.
Old 12-05-2011, 09:32 AM   #4
Rewards Points: 2,238
Hi! "mwong"
Looks like a 1/2 inch "gate" valve, with drain.
If you replace it use a "ball" valve, with drain.
The drain is the "knurled" cap on the bottom of the valve.
You might want to consider using a valve with "compression" fittings,
instead of "solder".
rossfingal
(Too slow!)
Looks like sweat.
rossfingal is offline   Reply With Quote
Old 12-05-2011, 11:01 AM   #5
DIY staff
That's a sweat fitting----odd to have that under the sink---a chrome 1/4 turn shut off with 3/8" outlet is more the standard thing---Those are available as a compression fitting---no need for a torch inside the cupboard.
Old 12-05-2011, 11:48 AM   #6
Should I remove the old valve and replace it with a 1/4 turn pipe pipe valve or should I just add the 1/4 turn pipe valve after the current valve.
Old 12-05-2011, 03:46 PM   #7
DIY staff
Can you take a picture from farther back so we can see the overall set-up under there?
There is no reason for double shut offs---but if the extra clutter doesn't bother you--the big old valve could stay----Mike---
Old 12-05-2011, 03:59 PM   #8
Option 1: I was thinking to cut out the old valve and disconnect the 3/8" tubing and install a new elbow joint
Option 2: Or make a cut after the old valve (leaving it in place) and putting in the new valve.
I like option 1.
Old 12-05-2011, 07:02 PM   #9
DIY staff
Option #3---Sweat off the old valve and wipe off as much solder as you can while its hot--
then either clean it up with sandpaper until it clean enough to use a compression angle shut off (5/8" nominal to 3/8") or use a sweat on (soldered) angle shut off valve--
I prefer Brasscraft --available at the Home Depot---to any other brand in the big box stores--
ben's plumbing (12-05-2011)
Old 12-05-2011, 07:09 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 840
All I can say is, they don't build them like they used to......thank goodness.......
The Following User Says Thank You to ddawg16 For This Useful Post:
VIPlumber (12-05-2011)
Old 12-07-2011, 12:33 AM   #11
Rewards Points: 370
Stop & waste, sweat sweat
Stop refers to the ball valve
Waste refers to the knurled nut, used to drain the water
Sweat sweat refers to the method of fastening the valve to the pipeing
fireguy is online now   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Gas valve on a bryant heavyduty HVAC 1 12-16-2009 09:42 AM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
