What Kind Of Service Line To Install? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2010, 11:53 AM   #1
What kind of service line to install?
We have recently purchase a commercial building built in the 20's and have opened a restaurant in it. I had to install a backflow valve to bring the water system up to code and found that the 1 inch galvanized service line is very corroded. In fact so corroded that when I removed a union the threads came right off the pipe. The line is about 50 feet long and is one inch. I will probably put galvanized back in, but would like to find out what other options there is. Line pressure runs about 85 pounds, but drops after the backflow valve. The rest of the plumbing in the building is new plastic.
Any help is appreciated.
Bob
62Galaxie is offline   Reply With Quote
Old 01-25-2010, 12:17 PM   #2
BIGRED
Rewards Points: 252
If code permits check out sleeved 1-1/4 to 2 inch copper. For commercial you will probably need the bigger pipe for better head and if you run all the way to the city's water main from your building you will eliminate any chance of pipes decaying underground or any lead pipes in the line.
Grampa Bud is offline   Reply With Quote
Old 01-25-2010, 01:45 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,... Don't even Think about it,.... Iron pipe, galvanized or not, is Not the answer...
I'd go with Plastics,... The bigger the better, right to the main if possible...
I've been workin' on this new Army base,... They're laying miles,+ miles of piping for all sorta fluids,...
None of it is Metal,... It's All plastics....
Matter of fact, the Only metal piping I've seen is the Heating,+ Fire Supression systems....
If it's Good enough for Uncle Sam,... It's gotta be the Best there is...
Old 01-25-2010, 02:27 PM   #4
A 60 foot roll of 1 1/4" Type K Copper tubing will run you about $700; and current code probably will require a water service larger than 1 1/4". 100 feet of 1 1/2" poly-pipe (polyethylene) will cost about $100. Check with your local plumbing/building inspector.
Ishmael is offline   Reply With Quote
Old 01-25-2010, 05:37 PM   #5
Not necessarily LOW BID.
SULTINI is offline   Reply With Quote
Old 01-25-2010, 08:13 PM   #6
Bondo's Avatar
Ayuh,... Low bid on High Specs....
Old 01-26-2010, 01:01 PM   #7
Rewards Points: 150
i agree
rudolph58 is offline   Reply With Quote
200 Amp or 400 Amp service Boontucky Electrical 37 07-24-2011 12:33 PM
Service Load Calcs and Install sstinman Electrical 47 09-04-2009 11:20 AM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 12:23 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
