What Kind Of Sealant Should I Use On This Type Of Fitting? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2012, 12:43 PM   #16
the piece that is too short can be replaced with an 1-1/2 threaded tailpiece. i had to do it once in 20 years. i had to heat the joint where it screws in to get it apart since they used something that dried hard but it did unscrew. then i doped up the new 12 inch piece and screwed it in tight and cut it too the length i needed. if you do this make sure you get the heavier gauge brass threaded tailpiece. you want 17 gauge.
Old 10-08-2012, 08:37 PM   #17
Rewards Points: 590
I solved the issue by gluing a pair of 22.5 degree pieces together and then cut down the existing drain down about 5 inches. Glued on my new 'part' and I was good to go! Thanks for all the help!
What kind of sealant should I use on this type of fitting?-photo-1.jpg   What kind of sealant should I use on this type of fitting?-photo-2.jpg   What kind of sealant should I use on this type of fitting?-photo-3.jpg
noone is offline   Reply With Quote
Old 10-08-2012, 09:11 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Ah see, that wasn't so hard, was it? Nice job.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
noone (10-08-2012)
Old 10-08-2012, 09:49 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 796
Now you know what a pair of 22's are
Old 10-08-2012, 10:20 PM   #20
Doing it myself
Alan's Avatar
I just thought you were making inappropriate posts again.
Journeyman Plumber
Old 10-08-2012, 10:25 PM   #21
Rewards Points: 590
Old 10-09-2012, 08:01 AM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,958
Actually....I was thinking bullets.....that, or a real tiny woman
ddawg16 is online now   Reply With Quote
Old 10-09-2012, 08:24 AM   #23
Rewards Points: 590
Pair o' skeeter bites?
Old 10-09-2012, 09:54 AM   #24
Plumber
Rewards Points: 796
A pair of 45's would be a bit much-- no?
Old 10-09-2012, 09:21 PM   #25
Doing it myself
Alan's Avatar
Definitely get ya more than an inch?
Journeyman Plumber
Upgrading an Outlet to 20 Amp /120 V grounded GFCI type Unicornz0 Electrical 19 10-02-2012 09:09 PM
Countertop sealant leaves granite with a dull finish? HeyItsJoel Tiling, ceramics, marble 6 05-31-2010 06:00 AM
Can I use this sealant (3M FD150+) on Class B flue? KatieAK Building & Construction 1 04-12-2010 04:35 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
