What Kind Of PEX Is This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2010, 08:03 AM   #1
What kind of PEX is this?
I'm trying to determine what type/brand of PEX connection this is. Can anyone help?
JPWMU is offline   Reply With Quote
Old 04-26-2010, 09:36 AM   #2
fabrk8r
fabrk8r's Avatar
I've never used that type of PEX connecting system, but it appears to be an Axis Pex connector. One name brand is Ardi Pex.
http://www.ardipex.com/pex-fittings-...stallation.php
It looks similar to ProPex, where a Pex expansion ring is expanded to fit over the end of the pipe and fitting and allowed to shrink. In the Axis system the tubing itself is expanded and then a copper, brass or stainless steel sleeve is crimped over the connection.
It looks to be a very robust connection, but may be overkill. Perhaps that's why I've never seen it used around here.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-26-2010, 09:58 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They call it rehau around here. You'll need to get a closer look at a fitting to be sure, but from what I understand you can use that fitting on all plastic versions of pex.
Journeyman Plumber
What kind of projector? Kurt1968 Home Theater 7 11-27-2009 08:24 PM
New kind of weed in lawn? VelvetFoot Landscaping & Lawn Care 9 11-14-2009 11:11 PM
what kind of pipe to use clasact Plumbing 24 10-05-2008 01:48 PM
What kind of breaker TaazKareem Electrical 22 09-26-2008 11:03 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
