What Kind Of Bath Tub Drain Is This? *pics* - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2009, 05:44 PM   #1
What kind of bath tub drain is this? *pics*
I recently bought a house and one of the tubs has a drain style I have never seen and can't find a replacement for. The stopper unscrews to open and screws to close. It is kind of like a lift and turn only this is threaded the entire way around the little stem. Turning as the only option. I have also tried to remove the drain with no luck. In fact I broke a plug wrench without budging the drain a millimeter. Any thoughts or light you can shed on what this is, where I can order replacement parts, etc would be helpful. I have tried all of the major home repair stores online and in person have not seen even a stopper that I can replace that would work with this drain. Thanks in advance.
ruggar is offline   Reply With Quote
Old 10-01-2009, 05:42 AM   #2
Remodeling Contractor
this will unscrew just like any other drain. Go to a plumber's store and buy the right tool or call a handyman.
Old 10-01-2009, 10:18 AM   #3
Home Remodeler
Rewards Points: 164
The rust on the tub may indicate your tub has rusted through, hope not. I have in the past had to use a chisel to remove them. Try the correct tool first. It may not budge, soak it first with some penetrating oil for a day or two. Good luck and let us know how you do.
mikey48 is offline   Reply With Quote
Old 10-02-2009, 01:08 PM   #4
Thank you for all of the advice. When it comes time to change out the drain I will definitely try some penetrating oil.
However, for right now I just want to simply replace the stopper that is lost. I am probably using the wrong word which is why the advice thus far is pointed towards removing the drain itself.
I just want to buy a replacement part that stops the water from flowing down the drain so I can take a bath. The plug? At any rate, most drains I have seen have a plug that either pops-up with pressure, you twist and pull up to lock in place, has a physical rubber plug or some other kind. This drain has a post that sticks up about a 1/2" above the drain. The plug screws up and down on the post to open and close the drain. I have never seen a plug/drain like this. This is not a simple turn and lock. This is a completely threaded plug. Like a valve stem on a tire. Unscrew to take the valve stem cap off to fill your tire with air. You unscrew the plug a little to let water down.
I have the same drain in another bathroom but I can't find a replacement plug on any online plumber supply or home repair type place. Any thoughts on style or type of drain/plug combo this is called?
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Drop in bath tub center drain to lft drain mikerich28@hotmail.com Remodeling 1 04-16-2008 08:48 PM
Bath tub leaking through Drain nitu_752002 Plumbing 5 03-31-2008 09:22 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Old Type Bath Drain Tool Junkie Plumbing 4 09-26-2007 03:05 PM
