Old 09-08-2012, 03:55 PM   #1
Rav
What kind of arrester to get for washing machine water hammer
I need advice on what kind of arrester to get for my washing machine water hammer. It occurs on the cold water supply multiple times when the washer is filling, as it cuts cold water in and out in order to make the water the proper temperature. I've looked on Amazon.com and seen so many choices by Sioux Chief, Oatey, etc., and many different types. I don't know what type to get. I've attached a picture of the valve and line going to the washing machine. If it helps any, the supply pipe is 5/8" copper; the valve and attached hose are "standard" as far as I know. Can any arrester be installed vertically, as my valve outlet seems to be? Thanks for any help.
Rav is offline   Reply With Quote
Old 09-08-2012, 06:24 PM   #2
This is how I did it (very inexpensive but effective).
If you are going to replace the shutoff, I would look into replacing it with a quarter turn valve.
allthumbsdiy is offline   Reply With Quote
Old 09-08-2012, 07:08 PM   #3
call me E
TheEplumber's Avatar
The easiest solution--http://www.amazon.com/Sioux-Chief-660-H-4-Inch-Female/dp/B000H5MQNM
Mount it on your machine, the hoses hang down and loop back up to your bib.
Every Sioux Chief I've installed said any position was fine
Old 09-09-2012, 10:43 PM   #4
Rav
Thanks, EPlumber. I picked that model up today at Home Depot, installed it in just a few minutes, and it works. Thanks very much.
The Following User Says Thank You to Rav For This Useful Post:
TheEplumber (09-09-2012)
Old 09-09-2012, 11:36 PM   #5
Master Plumber
Javiles's Avatar
Just a note, if those air chambers would have been sized correctly you may have had no problems.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Tags
hammer, machine, washing, water
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Do you see anything wrong with this water hammer arrester install? HVAC_NW Plumbing 7 01-28-2011 08:18 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
water hammer question seanstoner Plumbing 7 04-10-2006 05:28 PM
