What Kind Of Angle Stop Do I Have - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2012, 06:08 PM   #1
Rewards Points: 278
what kind of angle stop do I have
for my toilet I have copper pipe coming out of the wall and it has a large nut looking thing, then the valve is threaded onto the nut.. can't tell for sure as there is teflon tape on all the connections including the 3/8" comp hose!
I thought usually 1/2" pipe with compression fitting? Or does a sweat on pipe thread nut is common also?
I will have a picture soon.
DIYGST is offline   Reply With Quote
Old 12-14-2012, 06:14 PM   #2
Compression is common because no sweating. Threaded is common as well.
paintdrying is offline   Reply With Quote
Old 12-14-2012, 06:23 PM   #3
Roofmaster
Rewards Points: 2,172
I really do not like this type of fitting where the fitting is not captured. A shark bite or compression fitting is OK when it is inline and both sides are solidly clamped, but I really don't like then on the end of a stub out like the owner describes.
Old 12-14-2012, 06:28 PM   #4
Rewards Points: 278
what do you mean by captured?
I want to replace the valve because I think it is slowing the flow to fill the toilet.. with ball valve, just wanted to know the new valve to get.
Old 12-14-2012, 06:44 PM   #5
Rewards Points: 13,296
We can play the guessing game all night long or just post a picture and know know for sure.
How do you know it's the valve? Just shut the valve off, disconnet the line from the toilet and try running the water into a bucket to see if it's the valve.
Far more likly it the flush valve that's pluged up.
Old 12-14-2012, 06:44 PM   #6
DIY staff
Rewards Points: 7,174
Your description matches that of a compression shut off valve---
Old 12-14-2012, 06:46 PM   #7
Rewards Points: 278
I guess the teflon tape throw me off, why do people put teflon tape on any kind of threads?
Old 12-14-2012, 07:59 PM   #8
Rewards Points: 582
its called 5/8 compression x 3/8 compression angle valve..handle may say brasscraft....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (12-14-2012)
Old 12-14-2012, 09:45 PM   #9
Roofmaster
Its a right angle supply valve. There should not be Teflon tape on either nut, because the seal is not made at the threads. This type of valve should not be slowing down your flow. Adjust the float assembly so the lever drops further, and allows better flow.
Old 12-14-2012, 10:13 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If the valve is full of junk it will slow it down
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-15-2012, 02:37 AM   #11
Teflon tape? No such thing.
hvac benny is offline   Reply With Quote
Old 12-15-2012, 02:41 AM   #12
Rewards Points: 278
Please tell me what I am dealing with here.
looks to me something is not quite right why is there adapter after adapters
Old 12-15-2012, 04:08 AM   #13
plummen's Avatar
Your dealing with a lot of extra parts!
Just cut that mess off of there and install a 5/8x3/8 comp angle stop,preferably a 1/4 turn valve
Old 12-17-2012, 04:53 PM   #14
Rewards Points: 278
Anyone else have idea what are those adapters?
Is it a 3/4" MIP to 1/2 MIP for the 1/2" angle valve, it looks like a nipple type (male both ends) than the bushing type.
like this one?
Old 12-17-2012, 06:03 PM   #15
Remodeler
Rewards Points: 316
No, what you have is a compression union. 5/8" OD tubing x 1/2" MIP and that is in turn threaded into an angle stop valve.
The easiest solution is as plummen suggested, cut the pipe off right behind the nut and replace with a 5/8x3/8 compression angle stop. You have plenty of pipe sticking out to do so.
You just simply push the new valve onto the end of the pipe and tighten the compression nut while holding the body of the valve, it replaces all of that mess of parts. Your braided stainless line will then connect right onto the 3/8 port on the valve. Skip the teflon tape, not necessary at all with compression fittings.
You can buy this valve at most any local hardware store, here is an example of what you need. You just discard the small nut and ferrule and attach your braided stainless line. Take the old parts with you and if the store is competent at all they will fix you up in short order.
iamrfixit is online now   Reply With Quote
Air Handler Won't Stop Running, Help Please!!! Ralph III HVAC 31 06-02-2016 06:02 PM
Angle stop to toilet leaking Indeimogen Plumbing 3 05-11-2012 09:02 PM
Condenser's fan & compressor run stop run stop run stop, Please Help! tuanngnt HVAC 8 04-01-2012 12:07 PM
Is gravel stop needed for a torch down roof? sanfranman12 Roofing/Siding 7 02-12-2012 03:57 PM
Fire Stop jamiedolan Remodeling 7 03-03-2009 12:39 PM
