Old 09-17-2012, 06:17 PM   #1
What kind of ABS or PVC pipe cutter do you prefer
Hi guys. I have been using my mitre saw for years to cut ABS pipe schedule 40, normally between 1.5" and 3" (residential work mainly), this gives me a fast, square, straight and very clean cut I almost don't have to clean much (just a little shave with a knife inside and outside). If I need to shave just a little bit of the length of a pipe, I can easily do it with it. But I'm kind of tired of carrying the mitre saw with me just for this (but it works great once I have installed it). It's time to get to the next level or complete my collection of tools.
I'm looking at ebay and could find 2 models:
- Ratcheting PVC pipe Cutter 2-1/2"
http://www.ebay.com/itm/PVC-ABS-Pipe...item56468d704e
I have one smaller one I use to cut PEX 1/2" and 3/4" pipe and the cut is easy and clean, but not always is perpendicular to the pipe and I have to cut it again. How do this work for ABS 1-1/2" pipe? I kind of feel that ABS pipe is too hard to cut in this way.
-Then I see this one for bigger pipes (I have 2 smaller ones that I use only for copper pipe). How do you call this type of cutter?
http://www.ebay.com/itm/Ridgid-3-S-P...04%26rk%3D9%26
This one you clamp it around a pipe and do one or two turns around, then squeeze the lever a little bit, and repeat the cycle until you are done. This is awkward to use (especially the bigger models), need lots of space to maneuver (good luck to cut a pipe that is against a wall or in tight spaces), take much time to cut, but gives a clean cut easy to clean.
So, which one is the easiest, fastest that you use more often and why.
Pirulo is offline   Reply With Quote
Old 09-17-2012, 10:15 PM   #2
Doing it myself
Alan's Avatar
http://www.ridgid.com/Tools/Quick-Ac...s/EN/index.htm
Faster than a miter saw IMO.
Journeyman Plumber
Old 09-17-2012, 10:28 PM   #3
i have buth type the ratchet cuts good on pvc better but not always perfect but usable but not good at trimming a little off.
the plastic pipe cutter takes for ever and leaves a flared edge on solid core.
my first choice is miter box then sawzall for 3 and larger if the miter box is out i use it for 2 and smaller if not i use the ratchet cutters but longer handle then the one you showed in your ebay link
jaydevries is offline   Reply With Quote
Old 09-17-2012, 10:29 PM   #4
i have both types the ratchet cuts good on pvc better but not always perfect but usable but not good at trimming a little off.
the plastic pipe cutter takes forever and leaves a flared edge on solid core.
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
Old 09-17-2012, 10:48 PM   #5
Master Plumber
Javiles's Avatar
started doing PVC roughs in the 70s used a sawsall then use one now after a while you get proficient in your cuts, now i use all battery saws quick clean.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 09-17-2012, 11:21 PM   #6
chop saw works great and you always have a square cut and very few burrs to clean off. nowadays id use a cordless sawsall
Old 09-18-2012, 12:20 AM   #7
Thanks guys! So, I'm already with the right tool, the mitre saw, I don't see a need to use one of the manual ones, but the mitre box is actually a great idea if you have to do just a few cuts and is lightweight, I like that.
But I was waiting for somebody to recommend the X branded tool that has a battery, is portable, you do click and cut it all by itself, may be that doesn't exist.
Old 09-18-2012, 12:51 AM   #8
call me E
TheEplumber's Avatar
I have never seen a miter saw on a job site for plastic pipe.
Always used Rigid cutters or sawzall- faster and mobile, compact
Old 09-18-2012, 12:59 AM   #9
Yes, me neither, but believe me when I say it cuts really fast any abs pipe, is really handy (and very noisy!).
Old 09-18-2012, 01:02 AM   #10
call me E
Can you take it in a ditch or up a ladder? I don't like to walk around the job too much
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (09-18-2012)
Old 09-18-2012, 01:12 AM   #11
Nop. And I do walk. And you have a point!
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
what kind of pipe to use clasact Plumbing 24 10-05-2008 01:48 PM
