What kind of ABS or PVC pipe cutter do you prefer
Hi guys. I have been using my mitre saw for years to cut ABS pipe schedule 40, normally between 1.5" and 3" (residential work mainly), this gives me a fast, square, straight and very clean cut I almost don't have to clean much (just a little shave with a knife inside and outside). If I need to shave just a little bit of the length of a pipe, I can easily do it with it. But I'm kind of tired of carrying the mitre saw with me just for this (but it works great once I have installed it). It's time to get to the next level or complete my collection of tools.
I'm looking at ebay and could find 2 models: - Ratcheting PVC pipe Cutter 2-1/2" http://www.ebay.com/itm/PVC-ABS-Pipe...item56468d704e I have one smaller one I use to cut PEX 1/2" and 3/4" pipe and the cut is easy and clean, but not always is perpendicular to the pipe and I have to cut it again. How do this work for ABS 1-1/2" pipe? I kind of feel that ABS pipe is too hard to cut in this way. -Then I see this one for bigger pipes (I have 2 smaller ones that I use only for copper pipe). How do you call this type of cutter? http://www.ebay.com/itm/Ridgid-3-S-P...04%26rk%3D9%26 This one you clamp it around a pipe and do one or two turns around, then squeeze the lever a little bit, and repeat the cycle until you are done. This is awkward to use (especially the bigger models), need lots of space to maneuver (good luck to cut a pipe that is against a wall or in tight spaces), take much time to cut, but gives a clean cut easy to clean. So, which one is the easiest, fastest that you use more often and why. |
i have buth type the ratchet cuts good on pvc better but not always perfect but usable but not good at trimming a little off.
the plastic pipe cutter takes for ever and leaves a flared edge on solid core. my first choice is miter box then sawzall for 3 and larger if the miter box is out i use it for 2 and smaller if not i use the ratchet cutters but longer handle then the one you showed in your ebay link |
i have both types the ratchet cuts good on pvc better but not always perfect but usable but not good at trimming a little off.
the plastic pipe cutter takes forever and leaves a flared edge on solid core. my first choice is miter box then sawzall for 3 and larger if the miter box is out i use it for 2 and smaller if not i use the ratchet cutters but longer handle then the one you showed in your ebay link |
started doing PVC roughs in the 70s used a sawsall then use one now after a while you get proficient in your cuts, now i use all battery saws quick clean.
chop saw works great and you always have a square cut and very few burrs to clean off. nowadays id use a cordless sawsall
Thanks guys! So, I'm already with the right tool, the mitre saw, I don't see a need to use one of the manual ones, but the mitre box is actually a great idea if you have to do just a few cuts and is lightweight, I like that.
But I was waiting for somebody to recommend the X branded tool that has a battery, is portable, you do click and cut it all by itself, may be that doesn't exist. |
I have never seen a miter saw on a job site for plastic pipe.
Always used Rigid cutters or sawzall- faster and mobile, compact |
| All times are GMT -4. The time now is 02:54 AM. |
