Old 08-28-2011, 08:25 PM   #1
What is it, and how do I get rid of it?
The drain from the tub upstairs has been slow for years. I figured it’s a 20 year old house, and it’s a tub that’s not used very often. I have poured gallons of every kind of drain opening solvent I could find down it, and nothing seems to help. Last week it finally closed shut. Nothing was getting through. I went out and got a 50’ snake. My 25’ snake just could not get to the clog. I pushed my snake in and hit something solid. I figured it had to be a ‘T’ and I just could not make the turn. Down I went to the basement. Found a sharp 90, and decided I would cut it out and replace it with a sweep. When I cut the pipe, there was clog of gunk, a clay like substance that had settled and clogged the entire pipe. I ended up replacing about 3’ piece of pipe that was full of the stuff. It seemed almost like it was soap that had reformed in the pipe. It was solid, nothing was getting through. What was it? Could it be in my other pipes? How do I get rid of the stuff without having to replace the entire drain structure of the house? So far no other drains appear to be slow. Crossing my fingers???
becikeja is offline   Reply With Quote
Old 08-29-2011, 09:16 AM   #2
If it's not broke why fix it.
josall is offline   Reply With Quote
