What Happened To The Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2011, 11:20 AM   #1
vweater2001's Avatar
What happened to the Flange?
Wife wanted to change out the toilet from our downstairs powder room. So I complied and said I'd get to it that day. I had changed out toilets before and thought okay inspect and clean toilet flange, new toilet, wax ring, t-bolts and bam done. However, I went to change out the toilet on the downstairs powder room only to find it had 2 Extra Thick Wax Reinforced Rings and I didn't see a flange and one of the bolts (left side) was gone. Note that we have only been living at this home for 2 years and beginning to discover more things as we begin tackling a few remodels here in there. It's a condo so I'm at the mercy of only being able to do limited things from the walls in. I'm not a contractor by any means...so how do I fix this and how can I get the toilet back in to start using? Guys I'm breaking my brain trying to come up with something to get this thing up and running. Wife is getting discouraged as we don't have the money at the present time to hire a professional to come and do it. Please guys all your knowledge/feedback is greatly appreciated.
Thanks in advance!!
Mando
What happened to the Flange?-img00250-20110915-2311.jpg   What happened to the Flange?-img00251-20110915-2311.jpg
vweater2001 is offline   Reply With Quote
Old 09-23-2011, 02:19 PM   #2
AlbacoreShuffle's Avatar
This should get back up and running.
Its very easy to install.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
AlbacoreShuffle is offline   Reply With Quote
The Following User Says Thank You to AlbacoreShuffle For This Useful Post:
plumber666 (09-24-2011)
Old 09-27-2011, 11:02 AM   #3
Thanks, I actually installed it. I used a hammer drill to drill into the concrete then used tapcon anchors and walla installed a new flange. It was easy and I know how to do it now. Thanks for your help guys as I researched here more and found my answers. Put in new reinforced wax ring, new toilet...no leaks and wife couldn't be any more happy.
Old 09-27-2011, 01:23 PM   #4
Military Mom of 4
Snav's Avatar
Wow. Well, good - you took care of it.
Well - what happened, I believe, is that (most likely) the flange broken in the past and someone didn't repair it - they just figured that if the wax-seal was thick enough the flange wouldn't really be missed.
So - this enabled sewage water to back up into the cavity and slowly eat away at - well - your floor since it's highly acidic. That goo is no doubt years of human waste.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
