What The H--- Is This And Why Is It Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2013, 04:17 PM   #1
Rewards Points: 37
What the h--- is this and why is it leaking?
Suddenly started seeing rust stains on my basement workshop bench. Turns out they are coming from this "thing" ... What is it??? Do I need it? Should I replace it or rip it out and replace it with a straight through pipe?
Thanks!!
genEus is offline   Reply With Quote
Old 02-20-2013, 04:27 PM   #2
looks like a pressure reducing valve. if it is leaking replace it
Old 02-20-2013, 04:31 PM   #3
Rewards Points: 14,306
+1, time to rebuild it. There should be some info on the the side of it.
Far easyer to rebulid it then replace it.
Old 02-20-2013, 04:34 PM   #4
Rewards Points: 636
i agree or rebuild and do not by pass it or you might end up with more leaks depending on curb pressure
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-20-2013, 05:30 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 904
Looks like it in a copper line with a union nut on one side? If so replace it. Turn off the water, break the union loose, unthread from the male adapter. Reverse the order with a new PRV.
The Following User Says Thank You to TheEplumber For This Useful Post:
COLDIRON (02-21-2013)
Old 02-20-2013, 07:20 PM   #6
Rewards Points: 37
Thanks, all! Looks like I know what I'm doing this weekend!
Old 02-20-2013, 08:09 PM   #7
Rewards Points: 344
yup, Same thing happened to me awhile back. Cost me about 30 bucks for a new one. You are lucky like I was, thank god someone put a union their and it's threaded on the other end. Should be pretty easy to change out. Don't forget the pipe dope and teflon for the threaded part. I used both.
jmon is offline   Reply With Quote
Old 02-20-2013, 08:30 PM   #8
MarginallyQualified
Rewards Points: 2,464
Consider if there is a BETTER place to have it installed.
They're usually VERY close to where the water enters the house (at the valve).
Also consider adding a gauge or two.
Old 02-21-2013, 05:58 AM   #9
Rewards Points: 196
Do you have a boiler or forced air heating?
HVACTECH96 is offline   Reply With Quote
Old 02-21-2013, 06:04 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
[QUOTE=joecaption;1121188]+1, time to rebuild it. There should be some info on the the side of it.
Far easyer to rebulid it then replace it.[/QUOTE]
really
chrisn is online now   Reply With Quote
Old 02-21-2013, 06:06 AM   #11
Rewards Points: 37
yup, both. why?
Old 02-21-2013, 06:09 AM   #12
Rewards Points: 1,216
It had plenty of useful life replace it don't try to rebuild it. One little tear in a gasket or diaphragm and you get frustrated and end up buying a new one anyway.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-21-2013, 08:47 AM   #13
Rewards Points: 344
I use both teflon tape and pipe dope. I put pipe dope on threads first, then wrap it with a little teflon tape. Just my preference. I feel it seals better so there is no leaking/dripping afterwards. Threads can be pesky sometimes, especially when you are mixing metals.
You don't have to, you can use either or, it's up to you. I use to use just teflon tape, which is fine 99 percent of the time, but I had to go back and fix a couple drips. That's when I started using pipe dope as well. I haven't had any leaks, drips or errors yet when working with threaded pipe.
Put on threaded side only - nothing on the union side that should be fine.
Let us know how it turned out for you, or if you need anymore guidance.
Old 02-21-2013, 09:25 AM   #14
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've had a couple of watts 25AUB that I had to rebuild, because the darn connections were embedded in concrete. That style uses stainless screws to secure the top of the unit to the main body. That made it easy. Had it been the style pictured above, i'd have had the jackhammer out.
Otherwise, I disagree with joe. Usually easier to replace them, and not really that much more money.
Journeyman Plumber
Old 02-21-2013, 09:46 AM   #15
Jmon Teflon tape first then pipe dope other way squeezes dope out
joes plumbing is offline   Reply With Quote
The Following User Says Thank You to joes plumbing For This Useful Post:
jmon (02-21-2013)
