What Is A Good Ball Valve To Use - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2009, 01:30 PM   #1
OCDiy'er
what is a good ball valve to use
Just curious as to what sweat/solder in ball valve is well made, will not leak & will last?
Does not seem like many use Nibco - which everyplace seems to sell. Based on research some of the brands used by licensed/professional plumbers is Apollo and Red & White.
Also, refuse to buy any made in China (especially China), South Korea & Mexico - this severely limits what is available.
Thanks, Rob
wis_remod is offline   Reply With Quote
Old 04-02-2009, 08:02 AM   #2
RippySkippy's Avatar
Wow...you're not asking for much are you?
I can't think of one that will fit your needs and would suggest you head to the local plumb supply shop and start your quest. I'm guessing you've already exhausted the obvious at the big stores? I don't recall the brand of valves I purchased from Lowes...but they're 1/4 turn solid brass, they had a green label...and they are well made. Out of 20 or so that I installed one leaked from the seal between the handle and ball. Called the company, they sent a replacement plus 3 others...
Good luck!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-02-2009, 01:19 PM   #3
OCDiy'er
I am really looking for something decent not made in China, etc. - yeah, I know, good luck. After the China drywall issues, lead in toys, dog food, etc. I am trying diligently to buy stuff made in USA, or at least a country that seems to have some manufacturing credibility, but it seems to be more & more futile each day.
These valves are going in 3/4" lines that are going to supply water from basement 1" main line for a 2nd floor bath & new full bath. They are going to be in basement after 1" x 1" x 3/4" reducing tee before the pipe heads to 2nd floor. They will have the drain on them. This way if anything goes wrong with any 2nd floor plumbing it can be shut off & drained in basement. By isolating 2nd floor if there are problems with it we can still use plumbing (i.e. bath, kitchen, laundry, etc) on 1st floor and in basement.
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
