What The Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2011, 10:23 PM   #1
Question
What the flange?
Hey All,
I was planning on replacing the flange in the bathroom as I suspected it to be leaking. When I pulled the toilet one of the bolts came up with it since it was so rusted. As you can see in the photo the problem I have is the flange appears to be in some sort of ceramic. I'm thinking of just going at it with a hammer to get access to the rusted flange which will open up more work (releasing it from a CI pipe). What, if any, are your opinions.
Photo attached, red circles are where one bolt rusted out and another that just spins around.
Thanks for any help.
bc83 is offline   Reply With Quote
Old 01-07-2011, 11:23 PM   #2
DIY staff
Rewards Points: 7,174
What you have there is a cast iron flange packed with 3 pounds of plumbers putty---
Just scrape that dried putty out of there and the bolts should just lift out of the notches in the edge of the flange.
Brass bolts should have been used.---Mike--
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Tiling around tub with very wide flange petsparkle Kitchen & Bath Remodeling 3 04-20-2009 03:53 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
