What Fitting Do I Need For Sink To Drain Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2012, 08:36 AM   #1
Rewards Points: 77
What fitting do I need for Sink to Drain line?
In my kitchen remodel, the plumber roughed in 1.5" sch 40 pvc coming out of the wall horizontally for my drain.
I need to connect the schedule 40 to the 1.5" p-trap coming from the sink. What fitting do I put on the end of the schedule 40 so that I can connect it to the p-trap?
patented is offline   Reply With Quote
Old 11-21-2012, 09:24 AM   #2
Rewards Points: 13,458
http://www.bing.com/images/search?q=...BF772239C8156E
It comes as a whole assembly, fitting, nut, and tapered sealing ring.
patented (11-21-2012)
Old 11-21-2012, 09:34 AM   #3
you need one of these
http://www.amazon.com/Danco-94041-2-...s=trap+adapter
The Following User Says Thank You to DannyT For This Useful Post:
Old 11-21-2012, 09:56 AM   #4
Rewards Points: 77
Thanks Guys! Looks like exactly what I need!
Old 11-21-2012, 05:12 PM   #5
thy make a fitting that glues in the s40 and threded with comprestion fitting on the other end
Killer bee is offline   Reply With Quote
Old 11-21-2012, 08:02 PM   #6
Rewards Points: 582
you need a 1 1/2 desanko fitting....hub or spigot...ben sr
Order of install? floor, drain pan, pipe fitting, washer mcherno Plumbing 1 06-26-2012 08:47 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 02:28 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
