What Is This Fitting? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 02:19 PM   #1
Rewards Points: 30
What is this fitting?
See fitting circled in red in the attached picture. This is in the main drain trunk for a basement bath of a house I'm having built. I assume it's some sort of clean out, just seemed odd since there's that 4" standpipe right in front of it with a clean out opening. All of what you see in the picture is outside the house.
Just curious, thanks!
Todd
Todd1561 is offline   Reply With Quote
Old 10-14-2013, 03:18 PM   #2
MarginallyQualified
Rewards Points: 2,464
http://www.siouxchief.com/products/d...ckwater-valves
Old 10-14-2013, 03:30 PM   #3
Rewards Points: 30
Thanks! For those interested, it's basically a check valve that prevents sewage backups from overflowing out fixtures that are below grade, such is the case with my future basement. From my research they are only necessary if your lowest drain is less than 24" above the nearest sewer manhole. In my situation I'm several feet above the nearest manhole, so it probably isn't necessary, but can't hurt either.
Thanks again.
Old 10-14-2013, 06:07 PM   #4
Master Plumber
Benplumbing's Avatar
It's called a Backwater Valve
Benplumbing is offline   Reply With Quote
The Following User Says Thank You to Benplumbing For This Useful Post:
plummen (10-15-2013)
Old 10-14-2013, 09:11 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 674
If the city line backs up, your basement is now protected.
UPC states building drains below the sewer manhole rim need back flow protection.
Old 10-15-2013, 12:38 PM   #6
Plumber
Make sure that when it gets buried , you still have access to it.
Its NO fun running a drain cable through a back water valve, and then trying to retrieve it.
DidIDoThat is offline   Reply With Quote
The Following 2 Users Say Thank You to DidIDoThat For This Useful Post:
Benplumbing (10-15-2013), plummen (10-15-2013)
Old 10-15-2013, 12:44 PM   #7
Rewards Points: 30
Yeah they already have one of those black access boxes over it, that picture was from a while ago.
Thanks!
The Following User Says Thank You to Todd1561 For This Useful Post:
DidIDoThat (10-15-2013)
Old 10-15-2013, 08:15 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
They should have made that a double cleanout.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
