What Exactly Is Considered "short Cycling" On A Water Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2012, 08:51 AM   #16
Originally Posted by Fairview View Post
A common practice is to use a pail (s) / bucket (s) of known capacity to measure the gallons from when the pump has cut off to when the pump cuts in. Here again, don't spend time being too precise. If the measure is 3-4 gallons or less it raises our eye brows a bit but if the draw down is 5.5 gallons there is better things to concern ourselves with in life.
The easy diagnosis is when a quart or pint of draw down determines cut off / cut in.
I can tell you from experience it's no where near 3 gallon. If I had to guess less than a gallon.
damian51 is offline   Reply With Quote
Heat Pump Water Heater Review wassermeister Plumbing 0 08-25-2012 03:35 PM
NEED HELP with AC/ water pump system jin Plumbing 1 07-07-2012 09:45 AM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
