What Exactly Is Considered "short Cycling" On A Water Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2012, 07:26 PM   #1
What exactly is considered "short cycling" on a water well pump
I think my well might be short cycling. It cuts on at around 38ish and off at 60. It is on an 20 gallon bladder tank (well mate). With no water running besides the kitchen faucet on full blast, it takes around 20 seconds for the pump to cut on from full pressure. Once it cuts on it takes maybe 3-4 seconds to go to 60psi again. Does this sound odd to anyone else?
damian51 is offline   Reply With Quote
Old 10-27-2012, 08:23 PM   #2
DIY staff
Rewards Points: 7,174
Yep--that sounds like you have a pressure tank problem--
It should take more time between cycles---check the tank---
Old 10-27-2012, 08:56 PM   #3
Rewards Points: 582
shut off electric to pump drain holding tank...check bladder pressure is should be about 2psi less than cut in pressure....example cut in 40 psi bladder pressure 38 psi...ben sr
Old 10-27-2012, 09:10 PM   #4
Tank was installed new about 10 months ago
Old 10-27-2012, 09:17 PM   #5
Rewards Points: 582
ok it was installed 10 months ago..now what...did you do the test on bladder pressure ....ben sr
Old 10-27-2012, 09:29 PM   #6
How do I get all the warer out of the tank? Also forgot to say the pump is above ground jet pump if that matters. Tank is the well mate with quick connect fitting.
Old 10-27-2012, 09:40 PM   #7
Rewards Points: 582
just shut off power to pump so it don't come on ...open faucets to drain pressure off tank as low as you can....then check pressure from little valve on top of holding tank...
Old 10-27-2012, 10:47 PM   #8
It was 37 psi so it's ok. Although I did take too much out on accident and had to refill it with an air pump. One thing I am worried about was onc all the air pressure was gone, water came out of the stem..... It sure how that happens.
Old 10-27-2012, 10:51 PM   #9
Rewards Points: 582
if water came out you have a leak in bladder....ben sr
Old 10-28-2012, 12:08 AM   #10
Well lets hope it's under warranty. How much does a new tank run? Or can you replace just the bladder? Also how critical is it that I change it as fast as possible?
Old 10-28-2012, 06:43 AM   #11
An old Tradesmen
Rewards Points: 6,072
How important is keeping your electric bill low. And saving wear and tear on your water pump, so it last a long time yet.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (10-28-2012)
Old 10-28-2012, 08:02 AM   #12
DIY staff
Those tanks aren't a huge expense---not to difficult to replace,either----
You may want to call the well and pump company before you go ahead and DIY it--
Their price might not be out of reach----could be under warranty,too.
Old 10-28-2012, 09:03 AM   #13
Rewards Points: 370
The only accurate measure we have at this point to diagnose a potential problem is draw down gallons from cut out ( the higher pressure ) to cut in ( the lower pressure ). So I recommend researching the draw down gallons for your particular tank and measuring the gallons between the two aforementioned pressures. The time it takes to pump from low pressure cut in to high pressure cut out is moot at this time because we don't know the pump capabilities, depth of well, head pressure or pipe size etc.
As for water squirting from the air admittance valve, that's a poor diagnosis since it can very well be only condensation and one has to make a judgment call there.
Adjusting air pressure - - don't dwell on this too much since you are using two different gauges to set this pressure and gauges of that quality are manufactured to around + - 5 percent accuracy. Just do your best there with what you have at hand since right on the money isn't all that important and you aren't going to get exactly 2 lbs. lower anyway.
So what is short cycling. A rapid pressure drop that causes the pump to start long before the draw down amount in gallons is reached because of a lack of the proper air cushion in the tank.
Old 10-28-2012, 09:34 AM   #14
I know the draw down on the tank is 6.1 gallons @ 30/50 setting. I am not too sure how to measure the other drawdown.
Old 10-28-2012, 09:45 AM   #15
Rewards Points: 370
A common practice is to use a pail (s) / bucket (s) of known capacity to measure the gallons from when the pump has cut off to when the pump cuts in. Here again, don't spend time being too precise. If the measure is 3-4 gallons or less it raises our eye brows a bit but if the draw down is 5.5 gallons there is better things to concern ourselves with in life.
The easy diagnosis is when a quart or pint of draw down determines cut off / cut in.
Heat Pump Water Heater Review wassermeister Plumbing 0 08-25-2012 04:35 PM
NEED HELP with AC/ water pump system jin Plumbing 1 07-07-2012 10:45 AM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
