What Is Draining From My Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2010, 08:40 AM   #16
Rewards Points: 1,418
Originally Posted by Akpsdvan View Post
That is a good idea, my only challenge with that is the cheep plastic valves that one finds at the bottom of most water heaters... open them up and getting them closed could be a question..
(copied from another forum) The cheap plastic cap that comes with a daisy chainable lawn sprinkler (you should also be able to buy the cap separately) works fine on the water heater drain valve provided you did not lose the washer that came with the cap.
You do have to be able to get the valve itself almost closed first.
Problems with water heater jwise Plumbing 11 02-26-2010 08:36 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Water heater "leak"? TCinKC Plumbing 1 09-25-2008 01:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
