What Does This Pump Do??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2012, 08:57 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by jaydevries View Post
i have never heard of one being hooked to the drain of water heater
where does the pipes go that are hooked to the pump
That's how we always do them if there is room for the pump on the side of the heater.
Journeyman Plumber
Old 10-24-2012, 09:00 PM   #17
Doing it myself
Alan's Avatar
On a side note, that pump is like a 1/24 HP motor or even less (I think some are 1/64 HP). I'm sure the electricity that you will save by having a timer on it is minimal (timer probably cost more than what you will save over the life of the pump). More important probably and more expensive is the life of the pump motor not having it running 24/7.
Journeyman Plumber
Old 10-24-2012, 09:45 PM   #18
Rewards Points: 636
huh have always seen and done connection at cold supply .i have only done a few though and always willing to learn more what is the benefit of tying into drain
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 10-24-2012, 10:20 PM   #19
Doing it myself
Alan's Avatar
Easier to install IMO, you don't have a valve, and supply tubing and expansion tank to fight with. Same situation later if you have to work on the dumb thing.
Journeyman Plumber
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
