What Does This Pump Do??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2012, 08:58 PM   #1
What does this pump do???
I just bought a home that has some sort of pump hooked up to the bottom of my hot water heater and the pump is wired into a timer switch. (the same type of timer switch that is on my pool pump) I am including a picture of the setup in hopes that someone can tell what it does? The hot water heater is located in my garage. Thanks in advance!
Help Needed is offline   Reply With Quote
Old 10-24-2012, 08:59 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That's a recirculating pump. It moves the hot water throughout the hot water loop to keep the water hot at all your fixtures all the time.
Journeyman Plumber
Old 10-24-2012, 09:00 PM   #3
One thing I left out was that the line is connected to the drain at the bottom of my water heater. Thanks again for everyones help.
Old 10-24-2012, 09:02 PM   #4
What is the timer for? I flipped teh switch insde the timer box and the pump turned on...I quickly shut it back off because I had no idea where the pump was pumping water to.
Old 10-24-2012, 09:04 PM   #5
Does the pump turn on automatically when needed? Sorry for teh dumb questions...I went to my local big box home improvement store and they told me it was the help drain the water heater.
Old 10-24-2012, 09:26 PM   #6
Rewards Points: 582
they told you wrong..as stated its a recirculating pump...moves hot water through system ...so when you turn on hot water any where in house there is no waiting for hot water....timer should start pump at certain times as set by installer...ben sr
Old 10-24-2012, 09:35 PM   #7
Thank you both very much for the prompt reply...I promise, last question. The timer currently only has two set points... As of right now, the timer is set to go on at 6am and off at 12a. Is there a benefit to adding additional set points...like "on" a 6am and "off" at 12pm then "on" again at 6p and off at 10P. Or does it not really matter. Thanks again.
Old 10-24-2012, 09:35 PM   #8
Rewards Points: 630
i have never heard of one being hooked to the drain of water heater
where does the pipes go that are hooked to the pump
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 10-24-2012, 09:41 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 452
This made my day I'd go back to the store and school him and his manager
Your questions not dumb either.
You have something like this
Old 10-24-2012, 09:43 PM   #10
Jaydevries,
I would even know how to begin to answer your question. Now that I know what the pump is called and what is does, I have found a few installation examples on the internet and they show the pump installed in the same location as mine...Other than that, I have no idea where the pipes go or why it is hooked up like that...One thing I do know is that when I turn the hot water on in any area of the house, the water gets hot instantly.
The Following User Says Thank You to Help Needed For This Useful Post:
ben's plumbing (10-24-2012)
Old 10-24-2012, 09:44 PM   #11
Plumber
Rewards Points: 452
The return line is piped to the WH drain outlet- the boiler drain is removed and relocated
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 10-24-2012, 09:47 PM   #12
TheEplumber,
Your diagram really helped me understand how the pumps works...Thanks for everyones help.
Old 10-24-2012, 09:51 PM   #13
So, the only reamining question is...should the pump be set to run from 6a to 12a. (18 hours) seems i might be able to save on electric if i add some more on/off set points. Thoughts?
Old 10-24-2012, 09:54 PM   #14
When do you get up and when do you go to bed? You have to balance wasting electricity running the pump versus wasting water waiting for hot water. We do not stay up til midnight at my house, but we got kids.
broox is offline   Reply With Quote
Old 10-24-2012, 09:56 PM   #15
Doing it myself
Alan's Avatar
Good lord, I hate those guys. The timer is to save electricity while you are sleeping. Nothing more.
It turns off at night, and turns on during the day when you are more likely to need instant hot water.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 06:15 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 12:23 PM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 08:07 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 02:04 PM
