What Does This Pipe Do? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2013, 01:38 PM   #1
What does this pipe do?
There is a strange copper pipe with a cap coming out from the wall underneath the kitchen sink. The cap is crimped on.
In the picture, it has an orange cap, and it's above the cold water pipe on the right.
I have no idea what it's for...
Does anyone know what it's for?
SurfAndSand is offline   Reply With Quote
Old 08-14-2013, 02:33 PM   #2
Rewards Points: 34
Possibly for a refrigerator water/ice maker.
Dan
djlandkpl is offline   Reply With Quote
The Following 5 Users Say Thank You to djlandkpl For This Useful Post:
COLDIRON (08-15-2013), gregzoll (08-14-2013), jmon (08-14-2013), SurfAndSand (08-14-2013), VIPlumber (08-16-2013)
Old 08-14-2013, 07:31 PM   #3
Makes sense. Thanks!
Old 08-14-2013, 07:33 PM   #4
Right next to it, I have two outlets. I'm guessing one of them is for the Dishwasher, and the other for the Garbage disposal.
One of the outlets has 3 wires. The other outlet has only 2 wires. Care to take a guess which outlet is for the GD and the other for the DW?
If not don't worry about it - the circuit is clearly marked in my electrical panel, and I can just use a non-contact VM to tell me if there's current when I flip the switch.
Why would one of the outlets not have a ground though, is beyond me.
Old 08-14-2013, 07:38 PM   #5
Rewards Points: 34
What color are the wires?
Dan
Old 08-14-2013, 08:37 PM   #6
Rewards Points: 286
I would guess the 2 wire outlet is for the garbage disposal, and the 3 wire outlet is for the dishwasher.
Dug up this code reference. Read "exception" part. A seperate ground for your garbage disposal may not be needed. This may be why it's wired that way, I don't know. IMO, if everything is working fine and no one is getting shocked, I would just leave it alone.
422.16(B) Specific Appliances.
(1) Electrically Operated Kitchen Waste Disposers. Electrically operated kitchen waste disposers shall be permitted to be cord-and-plug-connected with a flexible cord identified as suitable for the purpose in the installation instructions of the appliance manufacturer, where all of the following conditions are met:
(1) The flexible cord shall be terminated with a grounding-type attachment plug.
Exception: A listed kitchen waste disposer distinctly marked to identify it as protected by a system of double insulation, or its equivalent, shall not be required to be terminated with a grounding-type attachment plug.
(2) The length of the cord shall not be less than 450 mm (18 in.) and not over 900 mm (36 in.).
(3) Receptacles shall be located to avoid physical damage to the flexible cord.
(4) The receptacle shall be accessible."
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Old 08-14-2013, 08:39 PM   #7
Wow! Thanks dude. I love this forum. You guys are so much more helpful than a automotive forum. :D
The Following User Says Thank You to SurfAndSand For This Useful Post:
jmon (08-14-2013)
Old 08-14-2013, 08:49 PM   #8
Rewards Points: 286
Your Welcome. Thanks, we are here to help anytime. Glad everything worked out for you.
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
