What Does "Cut A Pipe Square" Mean? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2010, 11:45 AM   #1
What does "Cut a pipe square" mean?
I'm still puttering with replacing my bathroom sink, and while I know there are many different opinons on products like Shark Bite - their instructions say to cut the pipe square.
What does that mean?
Thanks.
frozenmama is offline   Reply With Quote
Old 10-05-2010, 11:59 AM   #2
Chicago, IL
Michael Thomas's Avatar
The cut should be made a right angle to the pipe, rather than at an angle.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
frozenmama (10-05-2010)
Old 10-05-2010, 12:00 PM   #3
Rewards Points: 81
It means to make the cut at a right angle to the sides of the pipe. Imagine if you have to thread the end after you cut it. If there's any angle to the cut, you'll have a very hard time with it.
Remember that there are two axes you need to be straight on.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
The Following User Says Thank You to Jack Olsen For This Useful Post:
Old 10-05-2010, 12:00 PM   #4
Enough is Enough
H. A. S.'s Avatar
In machining, square is 90*. Not 89.5*, or 90.2*. Hope this helps.
H. A. S. is offline   Reply With Quote
The Following User Says Thank You to H. A. S. For This Useful Post:
Old 10-05-2010, 12:05 PM   #5
Thank you for your quick responses! Your descriptions made much more sense to me.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
