What To Do To Stop Sewer Gasses Durring Renovation - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 03:48 PM   #1
What to do to stop sewer gasses durring renovation
I searched the forums and couldn't quite find what I was looking for so I started a new thread, if this has been answered and I completely missed it then I apologize ahead of time.
At any rate, my wife and I are in the process of renovating our bathroom, we need to remove the toilet so that we can proceed with tearing up the remainder of the floor and then installing a new flooring. My question is what is the best method to keep any sewer gasses from coming into the bathroom during the whole process. I anticipate the demo and installation taking roughly three weeks due to time constraints. I read somewhere that a rag might suffice, or putting a garbage bag with newspaper stuffed in it then covered with duct tapped might work, I just don't know what the best method is.
Sorry this is so long winded, but thanks for the advice in advance I really appreciate it.
donmigga83 is offline   Reply With Quote
Old 03-23-2011, 03:51 PM   #2
they sell plugs for different sizes of pvc or abs with a big wingnut on them to expand them inside the pipe. I know i have seen them at HD or the blue place
here is what it looks like
http://www.hardwareandtools.com/Oate...g-8041709.html
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 03-23-2011, 04:00 PM   #3
Rewards Points: 674
...or a plastic bag and some rubber bands securing said bag.
Beepster is online now   Reply With Quote
Old 03-23-2011, 04:00 PM   #4
Thanks for the quick reply Danny - it looks as though I just take that test plug thing slip in into the sewer pipe, turn the handle till it holds on it's own and then I'm set. Is that the basic idea there?
Old 03-23-2011, 05:47 PM   #5
yes it is. we use to have to use them to block off the pipes for testing by filling with water. These were great you should be able to slip it into the toilet flange and just tighten until its snug. make sure you get the right size for your pipe. I was a plumber for 20 years until I got tired of smelling sewer gas and switched to carpentry. sawdust smells so much better.
Old 03-23-2011, 08:30 PM   #6
Rewards Points: 286
Several layers of good old-fashoined duct tape worked fine for me.
Jim F is offline   Reply With Quote
Old 03-23-2011, 09:03 PM   #7
Homerepairguy's Avatar
Rewards Points: 998
I just put some plastic bags into a plastic bag so that the whole thing is a tight fit in the pipe. Works better than rags (messy) or newspapers in a plastic bag (not soft enough).
HRG
Homerepairguy is offline   Reply With Quote
Old 03-23-2011, 11:03 PM   #8
Paper towels are what I use. A decent sized ball of them.
VIPlumber is offline   Reply With Quote
Old 03-24-2011, 07:35 AM   #9
I've just finished a forced renovation of our master bathroom and had the toilet off for a bit over a week. I just used paper towels and they worked fine.
Kiwi. is offline   Reply With Quote
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
