What To Do With The Sealed Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2009, 03:10 PM   #1
what to do with the sealed flange?
Hi there,
We have had an addition build on to our house for my mother-in-law. The plumbers that did the rough in used a sealed flange like thing for the toilet sewer pipe. What are we supposed to do with it? (Sorry if I am not using the correct terms). There is no hole in it, and it seems to be glued down tight.
Thanks so much
Smile
smileme is offline   Reply With Quote
Old 03-01-2009, 04:36 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Are you able to post a pic of the flange
Old 03-01-2009, 06:40 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
They probably used a toilet flange with a knockout in it. Just take a hammer and smack the center of the flange. The knockout should come out with one or two strikes. Be careful though, it is possible to drop the knockout down into the drain.
JDC is offline   Reply With Quote
Old 03-02-2009, 06:59 PM   #4
Thanks so much for the info...all worked out well, and toilet is installed...again..thanks
cast iron flange Jrebhun Plumbing 2 09-06-2008 12:45 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
