What To Do With Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2009, 11:16 PM   #1
What to do with Closet flange
I just tiled the floor in our master bath. The closet flange is now ~ 1/2" lower than the finished floor. I bought the extra thick wax ring, can/should I use this or should I purchase the flange extenders? I found some rotten sub-floor under the toilet and don't want to repeat that repair. I may purchase one flange extender depending on thickness and still use the jumbo wax ring. I also noticed the drain pipe is not straight up and down. It's is pitched ever so slightly. This is making the closet flange slight off level. Will the wax ring deal with this? It isn't off by much, but enough to notice.
jenoble99 is online now   Reply With Quote
Old 01-05-2009, 02:56 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Ideally, a toilet flange should be bolted to the top of the finished floor level with only the thickness of the flange above floor level.
If the bathroom is over a basement or crawlspace, I would cut the pipe and raise the flange to the proper level. If it's on a slab or an upper floor, then you can use extenders or doubled up wax rings. When I have to double wax rings, I use a regular ring on the bottom and a wax ring with a plastic horn on top. The wax should seal any slight unlevelness (if that's a word...lol) of the flange.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Closet flange: flush with finished floor, on on top of? rjhaleymd Plumbing 4 11-20-2008 07:43 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Metal Closet Flange darman16 Plumbing 11 03-23-2008 10:53 PM
Closet flange unsupported Richo Plumbing 6 01-02-2008 03:44 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 03:30 PM
