-   -   What is the difference between a quarter bend and short sweep 90? (http://www.diychatroom.com/f7/what-difference-between-quarter-bend-short-sweep-90-a-166680/)
troyce1 12-17-2012 08:30 AM
I am reading the IPC Table 706.3 regarding plumbing code, and have been unable to determine the difference between a quarter bend and a short sweep? It seems like they are the same thing, however the short sweep can be used when changing vertical to horizontal direction on drain piping, the quarter bend cannont....so there is obviously a difference.
Ishmael 12-17-2012 08:51 AM
I've always used those two terms interchangeably (as have my local wholesalers). But we also have what we refer to as a "vent 90" which is even tighter than a standard 90. Maybe that's what is technically/properly called a quarter bend in the IPC(?)
Here's a "vent 90": http://www.lowes.com/pd_23349-1814-P...ductId=3132769
Edited to add: Here in MA, a short-sweep (or "standard") 90 can be used to change from horizontal to vertical, NOT the other way around.
jagans 12-17-2012 09:01 AM
A quarter bend is a standard 90 degree elbow, as far as I know. Using the term "Short" and "Sweep" together is an oxymoron as far as I am concerned.
Alan 12-17-2012 09:10 AM
Are you sure you're reading that correctly? Doesn't sound like anything i've ever seen before. Read again please.
mr leak 12-23-2012 07:40 PM
troyce1 1/4 vs short sweep
Quarter bend is a simple 90 a vent 90 is to be used only for venting and more expensive so most use a quarter bend drain 90 for venting. There are short sweeps and long sweeps very much as the name implies these 90 fittings have a long and longer sweep to aid in drainage. Where flow is from horizontal to the horizontal long pattern fittings are necessary to prevent excessive reduction in velocity.Where the flow is from horizontal to vertical shorter pattern fittings are allowed because the acceleration of gravity maintains the flow A short sweep vertical to horizontal is only allowed for 2 " or smaller drains. Short sweeps horizontal to horizontal only 2 " or smaller IRC 2009 code
