What Is This Contraption In Front Of My House? Why Is It Dripping? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2009, 04:23 PM   #16
Rewards Points: 41
I finally got around to fixing this a few weeks ago...
I tested the water pressure at a hose-bib downstream from the PRV valve and found my water pressure was 118 PSI !!!!! And I verified that the contraption dripping water next to the PRV vale is an over-pressure valve. I cleaned off the face of the overpressure valve and found it is rated for 120 PSI - I guess that's why it's dripping - it is at the limit.
I picked up a single-union PRV valve from Home Depot - a Watts model for about $70. It was approximately the same size as the one that was installed. It took a little leverage to get the old PRV valve off, but it finally did come loose. The new valve installed without a hitch. When I turned the water back on, I was at 60 PSI and the over-pressure valve was no longer leaking (so I decided to leave it alone). The water pressure is noticably lower throughout the house. Showers no longer feel like you're being hit from above by a firehose (which I quite liked), but I'm sure the valves and other fixtures are thanking me for it.
Thanks all for your help and encouragement - a plumber wanted to charge me $275 to do the work.
fritzycat1 is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
purple martin/bat house pros and cons? DangerMouse Pest Control 12 01-15-2009 07:25 AM
No House Wrap On New House JoeZ430 Building & Construction 34 11-29-2007 10:51 AM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
