What Connectors Should I Use With PEX - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2010, 10:41 PM   #1
What connectors should i use with PEX
Bought a house that didnt get winterized and has busted pipes. Thinking about just starting over and using PEX. What should i use for the connectors? Sharkbite connectors look the easiest but are they reliable? I know they are hella expensive, but itd still be cheeper then hiring someone. Are the barb adn crimp kind reliable? The tool for them is expensive but i dont have a problem buying it if they are more reliable then the other options.
eagertolearn is offline   Reply With Quote
Old 07-29-2010, 10:46 PM   #2
Civil Engineer
Rewards Points: 4,566
I did my house using Wirsbo PEX. The fittings require an expansion tool, cost me about $300. Well worth it. I don't know anything about sharkbites, but I would stay away from brass fittings, see the lawsuit against Zurn for failure of their brass fittings. I use exclusively plastic fittings (Wirsbo polysulfone) with my PEX, except for valves that come in brass or stainless only. My well water is pretty acidic, so brass is a real problem.
Old 07-30-2010, 09:32 AM   #3
The sharkbites are copper not brass. Are there any national stores that sell the Wirsbo? Id like to look at the stuff. Friend of a friend use to do some plumbing but PEX was just coming in he said and the only advice he had was to use the right connectors otherwise the stuff leaks. I went to Lowes and HD late last night and was unimpressed with their selection of PEX.
Also in doing a forum search found where it said that 3/4" PEX is like 1/2" copper. I have 3/4" service so should i feed 1" Pex to the bathrooms and kitchen or is 3/4" sufficient. Origionally the house was done entirely with 3/8" flexable copper tubing.
Opinions of Ideal push-in wire connectors Bigplanz Electrical 62 07-03-2014 11:29 PM
Wire connectors Larryg Electrical 9 07-06-2010 11:14 AM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 09:26 PM
4x4" juntion box in 'leaky' location - no cover or romex connectors culturalenigma Electrical 9 07-29-2009 07:43 AM
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 05:33 AM
