What A Clog, Almost Finished And Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2008, 07:44 PM   #1
What a clog, almost finished and need help
I have a clogged drain in my upstairs bathroom for about 2 months. The 2 sinks in the bathroom drain and back up into the tub. I first used my shop vac to remove all the water I could. Then drano - nothing, Then crystals - nothing, Then this liquid stuff called guaranteed to work - nothing. Keep in mind I flushed it several times and removed the water with the shop-vac each time before the next chemical. Then I went and bought a snake. Put the entire 25 foot snake in and finally the drain broke free. So I flushed with hot water. All is good right??
Not so fast, then being the genius I am I filled the tub. I figured what better way to flush it then an entire tub of water. Pulled the drain open and water began flowing. It felt great, and then it stopped. Nothing flowed. I put the drain down waited about 10 seconds pulled the drain back up and it flowed again. I repeated this up and down activity;10 seconds up 10 seconds down and finally drained the tub. What's going on? any body have a suggestion??
becikeja is offline   Reply With Quote
Old 03-09-2008, 07:51 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The clog is still there, run the line again with the snake, chances are the snake you used may not be long enough
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-10-2008, 11:49 AM   #3
sestivers's Avatar
Rewards Points: 109
Next time, use mechanical methods (snake) before you resort to chemicals.
Steve
sestivers is online now   Reply With Quote
Old 03-19-2008, 07:42 PM   #4
It's been 9 days and all is well, not sure what happened the first time, but everything is working great now.
