What Can The Problem Be With My Shower Knob? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-10-2012, 10:35 PM   #1
Rewards Points: 335
what can the problem be with my shower knob?
I have a MOEN shower that has a single control knob. I recently got a new cartridge through MOEN and was in the process of removing the old. the inner cartridge came out but it left the outside collar still inside. How do I remove the plastic collar that is still inside? see pictures below.
also, If you look at the photo, on the right and left side of the center, there are the two screws that are for controlling the water flow. Kinda like a shut off valve for doing maintenance rather than having to turn off the main. ANYWAYS, the screw on the left is very tight to turn and no matter how much i turn that screw, it barely moves. What is causing this? The screw on the right, turns freely and when turn a quarter turn, the cold water flows. What do i do about the left screw? what is going on?
what can the problem be with my shower knob?-plastic-collar-within-1.jpg   what can the problem be with my shower knob?-plastic-collar-within-2.jpg
crankbait09 is offline   Reply With Quote
Newb needs help with shower knob repair mackdiesel Plumbing 7 05-22-2012 04:28 PM
Basement Shower Problem carolfleming Flooring 1 03-17-2011 08:17 PM
Valley single knob shower faucet navig97 Plumbing 1 06-22-2010 07:25 PM
Shower unit from Costco.door problem Carol f Plumbing 1 06-12-2010 05:29 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
