What Can I Seal This With? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2008, 04:42 PM   #1
What can I seal this with?
My shower is leaking around the outside of the drain, not inside the drain (see read spot on attached picture). What ever they used to seal between the shower pan and the drain has created a leak. I know the correct way would be to rip this out and redo it. But I'd like to try putting a sealant in the gap. What would be good sealant to use to fix this?
Thanks in advance,
Topaz
topaz is offline   Reply With Quote
Old 12-21-2008, 05:16 PM   #2
Rewards Points: 154
I don't think there is a "good" sealant for this application because anything will fail over time. The only right way to fix it is to take off the drain and re-install. You could throw some silicone around the drain and hope for the best, but you are on borrowed time.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 12-21-2008, 05:45 PM   #3
biggles's Avatar
clean out that area around the fitting with rubbing alcohol and old tooth brush scrub it goooood.get yourself a 2 part epoxy and first apply it around the ring area and wipe away they extra so you push it down tight into the plastic to tub contact point.let it set for a couple of days and repeat the application again leaving a little more......let that set and your tight.
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 12:58 PM
To seal or not to seal........ luce Flooring 1 05-18-2008 08:00 AM
Stink'n mice -- garage door seal... RippySkippy General DIY Discussions 6 03-03-2008 04:11 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
